Hello, you don't want to do that. The magnitude difference between the clip start and clip end should be around 7 or 8 for optimal display - The technical reason is floating point precision, you can look it up if you want.
Case in point :
Meaning you want Clip End / Clip Start < 10 000 000, ideally 1 000 000. Otherwise you'll start seeing ugly artifacts while moving around the viewport.
If you want to set it as a default, open a brand new file, change the values then go to File > Defaults > Save Startup File.
Case in point :
Meaning you want
Clip End / Clip Start < 10 000 000, ideally 1 000 000. Otherwise you'll start seeing ugly artifacts while moving around the viewport.If you want to set it as a default, open a brand new file, change the values then go to File > Defaults > Save Startup File.
Thanks!
