Distance looking
looking for a way to set this default as every high. unlimited if possible
  • edited April 2024
    Hello, you don't want to do that. The magnitude difference between the clip start and clip end should be around 7 or 8 for optimal display - The technical reason is floating point precision, you can look it up if you want.
    Case in point :
    Meaning you want Clip End / Clip Start < 10 000 000, ideally 1 000 000. Otherwise you'll start seeing ugly artifacts while moving around the viewport.
    If you want to set it as a default, open a brand new file, change the values then go to File > Defaults > Save Startup File.
    Andrej730Ace
