IfcTester: Bug for IDS in specification Pset_ManufacturerOccurence
Dear community,
I have started to use IDS in a project of mine with blenderBIM and trying some sustainable specification.
When I am setting up the property about Pset_ManufacturerOccurence, the IDS become invalid. I do assign this property to my ifc model in blenderbim. But the testing reulst failed. Does anybody know whats wrong with it?
I am using blender4.1 with blenderbim 240602, and i use usBIM online editor to write my ids file.
My orignial IDS file, since i cant upload IDS here so i change it to text.
You can see in the audit report that it is actually checking for the pset named
ManufacturerOccurence, notPset_ManufacturerOccurrence. This is probably because there is a typo when creating your IDS (Occurrence has two r)Another problem is that you are asking for an IfcLabel but the BarCode should be an IfcIdentifier.
Ys I did try what u say. But the file still valid.
Do I need to import a barcode instead of just type in something?
What does "Reserved prefix 'Pset_' for property set name (Pset_ManufacturerOccurence) in the context of Ifc2x3 on
property. " mean?You still didn't fix the typo, you need two R in occurrence. It should look like this:
It means that
Pset_is a special name that only buildingSMART can use. Once you fix the spelling mistake, the error should go away. If it does not, it's a bug with usBIM and feel free to report to them :)Thx
