Drawing Tests with the bisect mode and OpenCascade mode
@Moult, per your request, i ran some drawing tests with the bisect mode and OpenCascade mode.
- with
bisectmode: https://hub.openingdesign.com/OpeningDesign/Restaurant_MPM/commit/4a4eeca7b4d36ba99c2f0e79b495213510d63106 - with
OpenCascademode: https://hub.openingdesign.com/OpeningDesign/Restaurant_MPM/commit/026fd8b78080584cade7332f42805212e354e297
One discernable difference was when the OpenCascade mode was used on FLOOR PLAN - 1ST FLOOR
Here's a GIF showing the differences:
The other apparent glitch is that sometimes, the background projection lines don't seem to show up. This however, seemed inconsistent. Sometimes it worked, others it did not. Will keep an eye out if it's consistently reproducible.
This is super useful thankyou.
I found with one model switching between bisect / Opencascade and freestyle kinda broke the fill pattern congruency for all of them, but haven't been able to repeat it yet, I'll put screenshots if I see it again.
I'm a little confused. There are three modes here: Linework mode, Fill mode, and Cut mode.
So are you testing the Cut mode or Linework mode? Because the differences in your Gif are not cut elements, and so therefore Bisect doesn't apply.
Edit: I downloaded https://hub.openingdesign.com/OpeningDesign/Restaurant_MPM/src/commit/4a4eeca7b4d36ba99c2f0e79b495213510d63106/Open/Models/BlenderBIM/Restaurant_MPM.ifc and ran FLOOR PLAN - 1ST FLOOR with the Cut mode set at Bisect vs OCC and saw minimal differences.
My goals are to 1. make Bisect more robust than OCC's cut 2. see where we can improve Freestyle, knowing that it'll probably always fall a bit short of OCC.
These tests where only done comparing with 'Cut Mode'.
Will post other anomalies, if come across them.
That's really strange, I also only changed Cut mode and I didn't see those differences. Perhaps I need to have the full blend file with raster underlay and all the style settings? How do I download your complete project setup?
You can clone that entire repo. Do you have a pgp key? Will unlock the od_textures submodule.
Could you please share what app you used to make these GIFs? I'm curious!
https://getsharex.com/
Basically just a screencapture, and me flipping between svg's manually. :)
Thanks. I installed ShareX but I didn't know that it had a feature to make GIFs.
The following flips between
OpenCASCADEandFreestyleLinework Mode.The noticeable glitch is that the wall is not clipped, or voided out, with
OpenCASCADELinework Mode.fyi...the void is applied to the aggregate that the wall is in.
file: https://hub.openingdesign.com/OpeningDesign/Rae_Living_Room_Ext/src/commit/ac13f1ecba1037043209597ac9ad14c6bc998746/Open/Models/BlenderBIM/Rae_Living_Room_Ext.ifc
when you enter the mode to see the aggregate's voids, and then exit that mode, the voids go away....
https://community.osarch.org/uploads/editor/o4/1m4g7v3702w2.mp4
Yeah, some odd behavior, there's time when the projection lines go missing, and then when you run it again, they reappear.
see gif, when note that shows what the cut mode is.
These are all in 0.8.0, btw.
Same quirky behavior happens with cut mode: Bisect, as well...
nevermind, 'Shift + G' fixed this.
