A little known feature, but one of my favs...
you can select the value of an attribute or pset, and it will select all the objects that share that value.
I'm thinking maybe we need somewhere a button that will be possible to add to quick favorites, so user would be able to search by this query without setting up search UI or finding a similar element.
That's amazing, how does it even know? very cool!
Wow i didn't know that, thanks for sharing!
Added a quick way to sum up the qto/pset values of multiple selected objects.
Use Shift+click on the value. It also copies the value to the clipboard.
https://github.com/IfcOpenShell/IfcOpenShell/commit/fc57a7bbf40e96ac9d0129c04c0caac7de0e8989
Improved UI for BIM_PT_object_material
also can run
bim.select_by_materialby clicking on material namehttps://github.com/IfcOpenShell/IfcOpenShell/commit/a9defb94d0217f1c443cb21f29646ca78fb5ef74
@theoryshaw
nice one, thanks
PS if there was a way to reduce the number of decimal shown.. :)
Quick way to copy search strings from selections into clipboard...
https://github.com/IfcOpenShell/IfcOpenShell/commit/cb0fdbec660ce2d38151fc7f880f1303ef821abb
As always, love the soundtrack in the demo!
Select all instances that share the same attribute value as any of the selected objects
https://github.com/IfcOpenShell/IfcOpenShell/commit/b452348748629a6e6dad6df24e21bfad2c203043
use
shift + clickto remove that selection from the selection set.changed bim.select_similar.calculate_sum to
ctrl + clickinstead, sinceshift + clickis a UI pattern used in vanilla blender when selecting/deselecting things.https://github.com/IfcOpenShell/IfcOpenShell/commit/32e4a06fe4d299ddbf9ead641b1c85b6d775c3cd
