Where is Add Half Space
Please where is Half Space (or was it called boolean?) located now? It used to be under Add menu accompanied with Add Void, in recent Bonsai versions I can't find them.
  • edited February 1
    I was just about to ask about this
    Edit:
    There is an 'ApplyVoids' button when you select two intersecting objects, but I get an error when I use it
    os: Windows
    os_version: 10.0.22631
    python_version: 3.11.9
    architecture: ('64bit', 'WindowsPE')
    machine: AMD64
    processor: Intel64 Family 6 Model 151 Stepping 2, GenuineIntel
    blender_version: 4.3.2
    bonsai_version: 0.8.1-alpha250201
    bonsai_commit_hash: ea85a42
    AttributeError: 'NoneType' object has no attribute 'wrapped_data'
  • Well I found a fix for Voids not sure about Half Spaces
    Roel
  • Glad you figured it out, actually in my case I meant create new half space, to clarify myself, it used to be in this Add menu:
  • edited February 1
  • It has travelled more then I did during my last vacations :-)
    Thanks a lot @steverugi !
    steverugiNigelJohn
  • @Shegs
    please try this to add an opening in latest release :
    John
  • @steverugi said:
    @Shegs
    Nice... Will check it out
  • I think usability could be improved . A shortcut to add an opening would be nice, I counted 6 clicks to do what could be achieved with a shortcut in the header beforehand. Maybe added to right click context menu ?
    steverugiatomkarinca
  • Having the IfcFeatureElements, more immediately available would be nice... maybe something like this?...
    Shegszoomersteverugi
  • Yes, I think it'll go back to something like that, but first there's a bit more work to do to add more general support around all features, not just openings but also projections and surface features.
    RoeltheoryshawGorgious
