Tips for connecting elements without distorting them
Hi there, I want to join two elements of the same type that my modeller extracts as two separate entities.
I tried to select them and press CTRL+J to join them but the result is not appropriate because it's somehow distorted (look at the screenshot). How can I do this the right way?
Thanks,
Dennis
@mastrolube sounds like a possible bug. Can you please share example .ifc file to reproduce the issue?
Yes sure!
Seems to be some float precision error when saving geometry to IFC, I'll investigate.
Okay, I think it's fixed, new build will be available shortly in https://github.com/IfcOpenShell/IfcOpenShell/releases
https://github.com/IfcOpenShell/IfcOpenShell/commit/f6087613f06a1e36f970dedab276960739e87727
