IfcDoor disappears in aggregate Ifcwall after moving
Please try moving door...then regen with shiftG. Door will disappears...where am I wrong?
If you're new to bonsai, it's highly recommended to just save the .ifc file:
https://docs.bonsaibim.org/guides/troubleshooting.html#saving-and-loading-blend-files
Pardon, it's my first post
no problem... ask away.
No one has experienced this issue?
hi @Amerigo
In your .ifc file door and wall are in an IfcElementAssembly and, if you don't already know it, moving the door requires entering [tab] into it before doing it. Could that be the cause of the "disappearance" ?
To show it back select the door in the Outliner go to Geometry and Materials > Parametric Geometry > Door and click on the
+next to "No door found"ciao
Also, don't put the door 'in' the aggregate. If you do, it's voiding itself, so to speak. see video.
@steverugi @theoryshaw It works!...Many thanks. Ciao
