I got a problem with mouse tracking when drawing an element
edited March 2025 in General
I recently installed Bonsai and immediately noticed a bug. When adding an element, the square does not accurately follow the mouse, making precise drawings impossible. I have not found any other similar cases. This archive is a recording of the issue.
engfernando
  • Are you sure it's not just snapping to grid?
    Sure, I've already checked all the snaps, turned them off and on again. I even tested with bonsai's own meshes and normal meshes from blender itself, but the error persists.
  • Hi @Renang03, I'm not being able to reproduce. Does this happen in a specific file? Does this occur with Blender specific tools, such as moving an object?
    This happens regardless of the file, it happens in all of them. Specifically, this problem only exists for this tool, once the creation of an object with this tool is confirmed, the problem does not persist; performing any other transformation command does not present any problems.
  • Hi @Renang03, sorry for the late reply. I have made a few changes to the snapping system that may improve the performance. It should be available in the next release. Could you please test and let me know if your problem persists.
    carlopavsteverugiengfernando
