Some questions and thoughts after using BBIM for modeling for a while
I guess the right place for these is the Feature Requests section, or in some cases the Bugs section, but still, here are some thoughts and questions. I'll be using this same post to add them as they arise.
- When using metric units, the tool units displayed in the top-left corner of the 3D view should always show two decimal digits. Currently, for example, 3.65 is shown as 3.7 until you click and activate the dimension input field. Is there a way for user to change how many digits are displayed?
Hi. I agree with the first, I lost count of the amount of times I click there to check my wall height, even if I just need to check for reference, so I draw another wall. I don't know if is blender or bonsai code, but would be good to have the exact measurements right there.
About the second, I usually place my grid in the ifcsite, not in the storey, so rarely I have that issue - but I agree with you - if you see it, it should snap - I could be wrong, but seems to me a good feature to open in an issue
