BlenderBIM Bonsai attach documents
Hi all,
I want to attach some external documents (*.pdf, *.doc, etc.) to a ifc . I just want to enrich the ifc with this external documentation. for instance, a maintenance instruction manual to al IfcPipe. I want to associate documentation ( https://standards.buildingsmart.org/IFC/RELEASE/IFC4/ADD2_TC1/HTML/link/document-association.htm)
How can I do it? Is there a tutorial or Bonsay Documentation related to this topic?
Thanks
  • @Xemita
    please try "Documents" under project setup
    in location you can put the path to the document itself
    duarteframosRoelJohnwalpa
  • See also https://docs.ifcopenshell.org/autoapi/ifcopenshell/api/document/index.html if you want to add this data automatically via scripting.
  • edited April 2025
    Is this how "Levels of Detail" can be accomplished? If the referenced document is itself an IFC file we could have something like a tree structure for details. If I take the demo project for example:
    House.ifc would have for example IfcDoorType/DT01 or IfcFurnitureType/BUN01 with references to DT01.ifc and BUN01.if respectively.
    DT01.ifc could have references to Handle.ifc and Panel.ifc. Handle.ifc coud then have references to some pdfs about material, suppliers, etc.
    Thanks!
    steverugiOwura_qu
  • @steverugi:
    The Dialog Box defining the path to the external documents is not the same if I create a new IFC file from scratch inside Blender
    rather than if I open an external ifc (created by REVIT) and I try to attach the documents
    In my case, I cannot select the path to the files
  • edited April 2025
    @Xemita
    sorry, that is the first "container", to expand it where you can save your documents with location etc you need to click on the arrow
    I should have mentioned it in my previous post, hope it's now OK
  • Most likely your Revit IFC is IFC2X3 which is missing features. It's highly recommended to use IFC4.
    I'd say that library references, not document references, are more suitable for external geometry, but this is debatable.
    Owura_qu
  • Does it mean that best practice for implementing Levels of details would be for example to have a slab as a single rectangular extruded object in the main.ifc file and then this slab with a document reference towards an ifc file detailing beams& vaults and then the beams and the vaults with library refrences to standard vault and beam libraries?
    Does it make sense?
  • There currently is no best practice. It's uncharted territory. IFC has no "native" way to reference externally defined representations, and the best case for storing LOD currently is representation contexts with the target scale attribute or similar.
    Thoughts @aothms? How about a document reference or libary reference as an unofficial convention before IFC comes up with something?
  • to have a slab as a single rectangular extruded object in the main.ifc file and then this slab with a document reference towards an ifc file detailing beams& vaults and then the beams and the vaults with library refrences to standard vault and beam libraries?
    I would say closest to this is simply a BoundingBox representation or selectively processing IfcVoidingFeatures (or even IfcFeatureAdditions). Implementing proper LOD with the current technological basis of IFC to me just seems like an uphill battle with no end.
    Could be worth it to look into this in the context of IFC5 https://github.com/buildingSMART/IFC5-development/ where it's perfectly possible to have a high lod and a low lod layer that you can reference. If these have the same structure (think of it as a project library with same names - this works because in IFC5 reference are path-based), then you can selectively load the lod layer of choice at import time (or even load them both and selectively toggle between high and low lod in the viewer).
    JohnsteverugiwalpaKoAraAce
  • @Moult said:
    ... the best case for storing LOD currently is representation contexts with the target scale attribute or similar.
    Wait is there a tutorial or something that covers this? Didn't know that was possible!
  • edited May 2025
    I believe IfcArchitect has covered some detailing in this but I don’t know if “representation contexts with the target scale” as Dion says means something else than this.
  • edited May 2025
    Why are “DocumentOwner” and “Editors” attributes found in the IfcDocumentInformation not represented in the Bonsai. Almost all the other document attributes are in Bonsai except these 2.
    Or it’s hiding somewhere else I do not know about.
  • Those are not simple data types. I don't think we have an interface for it yet.
    Owura_qu
