Drawing perspective is not showing in SVG File
Hi
I' am trying to generate a perpective drawing in SVG file and I am not getting the result. Tha SVG page appears all in blank. I tried to edit the position of the IFCCamera and generates again, baut no result of this drawing.
A tutorial showing gerenrate the plan view it is OK, but the perspective view is another result
walpa
  • edited May 5
    Hello @Antonio_Dias ! did you try to set the linework mode to Freestyle?
    PS I also do not remember how to set the view to perspective, I'm only able to make it orthographic :)
    Antonio_Dias
  • You can set the view to perspective with the vanilla camera properties. I tested it and set it to freestyle and seems to work. However took something like 2 mins to spew out this simple cube so you may want to go make a coffee after clicking on the button.
    carlopavwalpaMassimoBedson
    Thank for the answer. I did some tests and I had the same result. Just in orthographic...
    Thank you @Gorgious ...in my tests i had result only in orthographic...I will continue doing tests
    Dear @carlopav I did not notice and I did not have the Add-On the Blender Freestyle Exporter SVG installed...now I had the first result
    Thanks a lot man
  • edited May 5
    If you're okay without wireframe edges, you can use overlay, and it works in OpenCASCADE linework mode.
    Also, you can turn on the following.... and it will get you 'rastered' linework.
    Antonio_Dias
  • Please what is exactly the workflow?..It's all in blank
    walpa
  • Dear @Amerigo ...you have to download the addon Freestyle export SVG in Blender Bonsai...after that enable freestyle in options of Drawing Perspective
    steverugiMassimowalpa
  • edited May 9
    I've done that...!
