I have noticed that with recent Bonsai builds that:
1. the (Shift+T) Trim tool only does a mitre, there are situations where I want to do a butt join at corners.
2. the (Shift+G) regen tool is not working.
Blender 4.3.2 Bonsai v0.8.3 alpha 250423
Is it just me? or are these features or bugs :)
Have you messed around with layer priorities?
I think the
shift-gtool looks like it's not regenerating, but i think that's only the 'cut decorator' that's not regenerating. If you active the drawing again, you can see the cut decorator is refreshed.related: https://github.com/IfcOpenShell/IfcOpenShell/issues/6495
Hi @theoryshaw, sorry for the radio silence, I haven't been able to get back to Bonsai for a week or so, life happens.
I don't understand the ' active the drawing again' bit of your post. I have the same issue on both my computers each Blender 4.3.2 Bonsai v0.8.3 alpha 250509.
Could I have changed something to cause this?
I have this gif to show what I mean in case my explanation is lacking
i gottcha. Yes,
Shift + Gused to work on walls, but in your video above, the only way would be to regen the window, and then the wall regens.So yes, i think that's either a bug, or feature request. I have a feeling it's an unattended bug.
I have read and watched Have the ifcopeninglement be locked to the window/door location. #6671 I thought the **ifcopeninglement **was previously locked to the window/door in the past or am I mistaken?
Only for "parametric" windows.
same result when I bring in a Project Library asset too.
