export the width and height and height along with the door type. Is there a way to do that?
  • @falken10vdl said:
    Cheers!
    Hi, I want to export the width and height and height along with the door type. Is there a way to do that?
  • edited June 2025
    @arunarchitect
    you can use attributes:
    arunarchitect
  • edited June 2025
    ..or you can use Qto (shift-Q) to fill the Qto_DoorBaseQuantities, try Blender engine for doors:
    PS difference between the two methods I believe is due to the second using the overall dimensions, including Lining
    arunarchitectwalpa
  • edited June 2025
    Thank you @steverugi . Also from where we can get these formulas, like type.Name, Qto_DoorBaseQuantities.Width etc?
  • @arunarchitect
    Selector page is one
    To understand it better I normally go to the IFC page of the element, here the door one.
    Let me know if you need further info, no problem
    arunarchitectwalpatheoryshawfalken10vdl
