Linked IFC - snapping?
Sorry if this is has been raised previously. Should we be able to snap to Linked IFC models? I'm sure that we used to be able to back when Links were loaded as 'Chunk' meshes.
On later versions the handling of linked models seems to have changed - does this mean we can no longer snap? Or is there a setting I'm missing somewhere? Thanks
It used to work. I’ll check how those changes affected the snapping system
