How do i assign OpenCASCADE representation to a IfcElement?
I'm trying to create a ifc element from a OpenCASCADE representation following the tutorial here:
https://docs.ifcopenshell.org/ifcopenshell-python/geometry_creation.html#opencascade-representations
I manage to create a IfcProductDefinitionShape but I don't understand how to assign this to a IfcElement
Here is my code:
import ifcopenshell
import ifcopenshell.geom
from OCC.Core.gp import gp_Pnt
from OCC.Core.BRepPrimAPI import BRepPrimAPI_MakeBox
from OCC.Core.BRepAlgoAPI import BRepAlgoAPI_Cut
from pprint import pprint
import ifcopenshell.api.root
import ifcopenshell.api.unit
import ifcopenshell.api.context
import ifcopenshell.api.project
import ifcopenshell.api.geometry
model = ifcopenshell.open('empty.ifc')
outer = BRepPrimAPI_MakeBox(gp_Pnt(-5000., -180., -2000.), gp_Pnt(5000., 5180., 3000.)).Shape()
inner = BRepPrimAPI_MakeBox(gp_Pnt(-4640., 180., 0.), gp_Pnt(4640., 4820., 3000.)).Shape()
window1 = BRepPrimAPI_MakeBox(gp_Pnt(-5000., -180., 400.), gp_Pnt( 500., 1180., 2000.)).Shape()
window2 = BRepPrimAPI_MakeBox(gp_Pnt( 2070., -180., 400.), gp_Pnt(3930., 180., 2000.)).Shape()
building_shell = BRepAlgoAPI_Cut(
BRepAlgoAPI_Cut(
BRepAlgoAPI_Cut(outer, inner).Shape(),
window1
).Shape(),
window2
).Shape()
# model = ifcopenshell.file(schema="IFC4")
product_definition = ifcopenshell.geom.serialise("IFC4", building_shell, False)
product_definition = model.add(product_definition)
pprint(
product_definition.get_info()
element = ifcopenshell.api.root.create_entity(model, ifc_class="IfcFurniture")
model.write('new.ifc')
{'Description': None,
'Name': None,
'Representations': (#240=IfcShapeRepresentation($,'Body','Brep',(#239)),),
'id': 241,
'type': 'IfcProductDefinitionShape'}
Hi, if it's
IfcProductDefinitionShape, then you need to assign it toelement.Representation.See the documentation - https://ifc43-docs.standards.buildingsmart.org/IFC/RELEASE/IFC4x3/HTML/lexical/IfcFurniture.htm
@Andrej730 i think that's what I'm doing with
ifcopenshell.api.geometry.assign_representation, right?But then I'm also producing a invalid IFC.
Here's my code:
and running the validation:
I've figured it out.
But the representation in Blender seems off. Is this a current limitation, or am i still doing something wrong?
Do you have "Backface Culling" turned on? That kind of looks like some of the normals are flipped, and backface culling is active.
@sjb007 no, that is turned off. Attached the IFC file
Ah OK. Uneducated guess here, but it looks like a bug in the default
Hybrid CGAL-OCCgeometry library that gets used. The only one that works is plainOpenCASCADE. When opening the file use the Enable Advanced Mode, and set the Geometry Library option:And you should get:
You should probably raise a bug against IfcOpenShell in Github as well. Considering your script is essentially the example in the documentation for geometry creation, it's curious that the other geometry libraries cannot handle it.
@sjb007 THANK YOU!
here the bug report: https://github.com/IfcOpenShell/IfcOpenShell/issues/7099
