Difference between wall type edit tools and wall edit tools when select a wall
Greetings to everyone!
I created a wall and when I select the wall I see "Wall Type Edit Tools" and then I removed object material then when I select the same wall, I see "Wall Edit tools" after this when I try to insert a wall a popup says "No Geometry". This popup works even I try to close the file from the Blender file menu at the top. You have to right click to exit from the command.
I tried to load the material back with pressing + icon but again I see "No Geometry" popup.
I am new and experimenting with Bonsai BIM but this "No Geometry" popup behavior looks buggy to me.
Blender 4.5.3 Bonsai v0.8.4-alpha251012-0073a4c
  • Hi. Welcome. Possible to upload a .mp4 of your workflow?
  • edited October 2025
    for exit I right click at the end of the video. When I choose IfcMaterialLayerSet the toolbar brings back but "no geometry" message for new walls continue
  • When you deleted the 'IfcMaterialLayerSet' you deleted the parametrics behind the wall type.
    so when you tried to create a new instance for that type, it says no geometry, because there's no geometry instructions now for that type.
    Or perhaps i'm missing what you're asking.
  • Thank you very much for explanation. I thought I only deleted the information on that wall, but is it normal for this popup window to be active on the side panels and menus as well?
  • yes, if i'm following you correctly.
