bonsaiPR: your weekly build with PRs merged (as much as possible)
Following discussion https://community.osarch.org/discussion/comment/26664 please find here a repository with all possible merges of PRs done automatically.
I will run it weekly and keep the last 4 weeks.
I hope this serves for users to provide feedback on the available PRs. Note that if the build does not work, please reach out to the PR authors or me (I will be able to test on linux or windows).
The build is following the PRs in decreasing number order so some PRs are not succeeding due to other previous merged PRs.
If you guys think that the PRs should follow other order, let me know so the build is done accordingly.
I have replaced (hopefully everywhere were it is needed) the word "bonsai" with the word "bonsaiPR" so it should be simple to know that this is the bonsaiPR addon not to confuse with bonsai.
The idea is to have the possibility to disable one and enable the other whenever needed
Of course one should disable one before enabling the other.
Here is the project:
https://github.com/falken10vdl/bonsaiPR
Under releases you have the zips for the addons:
https://github.com/falken10vdl/bonsaiPR/releases
The full report on how each one of the PR was merged is in the assets as README log file. I have provided the list by author so it is simpler for each PR author to check them.
I hope you find it useful.
Cheers!
theoryshawzoomerMaswalpabrunopostleMassimoDimitrissteverugiGerardTatomkarinca
«134
  • If the core developers find it useful maybe this can be hosted directly in ifcOpenShell github page.
    Cheers!
    theoryshawzoomerwalpabrunopostle
  • Very cool. Would it be possible to maintain a pullable branch that has all these merged as well?
    That makes testing easier, as you can check out at certain dates, etc.
    zoomer
  • This is really, really good! Let's see how people use it, and if it works well it'll be great to use an official ifcopenshell org name in Github and link to it in docs.
    theoryshawfalken10vdlMassimo
  • edited October 2025
    @theoryshaw I have updated the project https://github.com/falken10vdl/bonsaiPR
    On a weekly basis I will create a branch that you can pull with the merges done:
    The structure now has an automation folder and source folder.
    • The automation holds all the scripts that I run to make these so anyone can try it locally if he/she wants.
    • The source directory has the code for bonsai with the successfully merged PRs so one can fetch it to see why the not successful ones did not make it
      Cheers!
  • Cool, one last request, is it possible to have this branch, just be a fork of the IfcOpenShell repo?
    That way, all the symlinks work, as setup in our development environments.
    and we can check out from one branch to another easily.
    @theoryshaw This was an overhaul :) I found out that github does not allow me to have two forks from the same project IfcOpenShell/IfcOpenShell so I had to use the fork I was using to create my own PRs to also have weekly builds of the merged PRs:
    So now the falken10vdl/bonsaiPR (https://github.com/falken10vdl/bonsaiPR) just holds the addons as assets (and the automation code for whoever wants to take a look) that can be used by end users and the branches in falken10vdl/IfcOpenShell can be used by the PR authors
    Cheers!
    So cool!... so for the hassle. :)
    Would it be possible not to merge the 'drafts'?
    https://github.com/IfcOpenShell/IfcOpenShell/pulls?q=is:pr+is:open+is:draft
    There are times, i create a PR with broken code, to try and just get some help. I wouldn't want to unnecessarily add that noise to this 'bleeding_edge' branch.
    I wonder too, as maintainers, perhaps we should convert the PR's to 'drafts' before explicitly being told by the PR's author, they are ready to pull.
  • @theoryshaw Good feedback! I just added those in the SKIPPED section. If you go to a release it looks now like this:
    Cheers!
    theoryshaw
    I wonder why it isn't possible to configure github to force all new PR's to draft by default. Then the submitter can set it to Ready for Review for review and merge. See https://github.com/orgs/community/discussions/6943 - 4 years... 🤷
    theoryshaw
    Question to AI: Just thinking out loud.... Let's say we create this bleeding edge branch for bonsaibim and ifcopenshell. And i use this bleeding edge on the projects .ifc projects posted here: https://hub.openingdesign.com/ Could there be a way to automatically test incoming .ifc files with something like the buildingSMART validator, or the like. That way, if the .ifc file becomes invalid, we'd know right away the bleeding edge branch codified the .ifc incorrectly.
    Chat with AI...
    Ohhh — yes. ✅
    This is a brilliant idea and exactly the kind of “safety net” that makes a bleeding_edge branch sustainable:
    • fast merges,
    • real projects being tested automatically,
    • and early warnings when the branch starts producing invalid IFC.
    And yes — what you’re describing can absolutely be automated.
    Let’s break it down step by step:
    🧪 What You’re Proposing
    • Maintain a bleeding_edge branch for BonsaiBIM and IfcOpenShell.
    • Regularly test real-world .ifc models (e.g. from hub.openingdesign.com).
    • Run an IFC validation process automatically (e.g. using the buildingSMART IFC Validation Service or similar tools).
    • If the validation fails → alert maintainers, or even automatically flag the offending PR.
    🧰 How You Could Set This Up
    1. Establish a Model Test Suite
    • Select a representative set of real .ifc files from the OpeningDesign hub.
    • Store them either:
      • In a dedicated repo (e.g. bonsaibim-ifc-tests)
      • Or reference their URLs if they can be reliably fetched.
    • This becomes your “canary project set.”
    📝 Tip: Start with 3–5 small to medium IFCs, but aim for variety (architectural, MEP, different schema versions, etc.).
    2. Trigger CI/CD on Every Bleeding Edge Commit
    • Use GitHub Actions (or Forgejo CI if you’re self-hosting) to run a workflow when:
      • PRs are merged into bleeding_edge
      • Or on a nightly schedule
    • The workflow will:
      1. Pull the latest bleeding edge build.
      2. Download/open each .ifc file in the canary set.
      3. Run a validation process.
    3. Validation Options
    🧭 Option A: Official IFC Validator
    • buildingSMART IFC Validation Service provides:
      • A public web validator (for manual checks)
      • APIs (for programmatic use, though you may need credentials / setup)
    • CI can POST IFC files to the validator and check the returned report for errors.
    ✅ Pros: authoritative validation.
    ⚠️ Cons: external dependency, may need rate limiting or API agreement.
    🧰 Option B: Local / CLI Validation Tools
    • Use IfcOpenShell’s built-in validation utilities or something like:
      • ifcopenshell.validate() in Python (basic schema checks).
      • xBIM Toolkit (on Windows, C#).
      • BlenderBIM Add-on’s validation features (headless mode).
    ✅ Pros: runs locally in CI, no external dependency.
    ⚠️ Cons: may not be as rigorous as buildingSMART’s validator.
    🧪 Option C: Hybrid
    • Run fast local checks on every commit.
    • Run the full buildingSMART validation nightly or weekly.
    • This balances speed and depth.
    4. Reporting the Results
    • If a validation fails:
      • Post a GitHub/Forgejo status check with pass/fail.
      • Link to the report (e.g., “Geometry invalid: entity X missing required attribute”).
      • Optionally: open an issue or comment on the PR that last touched the code.
    5. Optional Enhancements
    • Diff IFCs: run before/after comparisons to detect unexpected structural changes.
    • Schema evolution tests: ensure output is still valid for IFC2x3, IFC4, IFC4.3, etc.
    • Performance metrics: detect if bleeding edge made models heavier or slower to export.
    ⚡ Result
    If any bleeding edge commit or PR breaks IFC validity, you’d know:
    • within minutes, if it’s caught by CI
    • or within a day, if it’s caught by a scheduled nightly run
      → That gives you fast feedback and keeps main clean.
    And — since you’re using real projects from OpeningDesign, your test suite is not just synthetic. It reflects actual production use, which makes it far more meaningful than toy tests.
  • @theoryshaw A better solution would be server-side validation of every git commit to an IFC project. Ideally this would be integrated into forgejo, but it can also be done now with normal Github CI tools - ifcopenshell with the validator is just a pip install.
    theoryshaw
  • @brunopostle Can you elaborate a little bit more? what is the difference between ifc openshell validator and buildingSMART validator?
    Thanks!
    theoryshaw
  • @falken10vdl I believe they are the same thing.
    We have a git based workflow where Bonsai can commit changes and push IFC files to remote git repositories. With normal source code you can configure a lint checker in Github to check all commits and pull requests, we should do the same and validate IFC data with every commit (similarly, drop some IDS files into the repository and automatically check the model with these).
    falken10vdl
  • Ok, that was easy. In your IFC Git repository create a file called .github/workflows/ifc-lint.yml and put this in it:
    name: IFC Validation
    on:
      push:
      pull_request:
    jobs:
      lint-ifc:
        runs-on: ubuntu-latest
        steps:
          - name: Checkout repository
            uses: actions/checkout@v3
          - name: Set up Python
            uses: actions/setup-python@v4
            with:
              python-version: '3.x'
          - name: Install ifcopenshell
            run: |
              pip install pytest
              pip install ifcopenshell
          - name: Run IFC lint checks
            run: |
              set -e
              shopt -s globstar nullglob
              for file in **/*.ifc; do
                echo "Validating $file..."
                python3 -m ifcopenshell.validate --rules "$file"
              done
  • ..and here's another one: automatic IDS checking.
    Create an IDS folder in the root of your repository and add some IDS files that you want to use to check your IFC model, as many as you like.
    Create a .github/workflows/ids-lint.yml file with this content:
    name: IDS Compliance Check
    on:
      push:
      pull_request:
      workflow_dispatch:
    jobs:
      ids-lint:
        steps:
            with:
              python-version: '3.10'
          - name: Install ifctester
            run: pip install ifctester
          - name: Run ifctester for all IDS/IFC combinations
            run: |
              ids_files=(IDS/**/*.ids)
              ifc_files=(**/*.ifc)
              if [ ${#ids_files[@]} -eq 0 ]; then
                echo "No IDS files found in IDS/"
                exit 1
              fi
              if [ ${#ifc_files[@]} -eq 0 ]; then
                echo "No IFC files found"
                exit 1
              fi
              failed=0
              for ids in "${ids_files[@]}"; do
                for ifc in "${ifc_files[@]}"; do
                  echo "▶ Validating $ifc with $ids"
                  if ! python3 -m ifctester --no-color "$ids" "$ifc"; then
                    echo "❌ Validation failed for $ifc with $ids"
                    failed=1
                  fi
                done
              done
              if [ "$failed" -ne 0 ]; then
                echo "❌ Some IFC/IDS validations failed."
                exit 1
              else
                echo "✅ All IFC/IDS validations passed."
              fi
    ..and here is what the results look like in Github, formatting is a bit texty, and ifctester doesn't seem to return pass/fail:
  • I realise I hijacked this post, but then provided something useful that has been often desired - could someone with admin permission split this into a separate post on Continuous Integration (CI) for IFC projects ?
  • I would keep it in. I asked, and think it aligned with finding ways to improve the testing of this bleeding_edge branch. @falken10vdl that okay?
  • @brunopostle @theoryshaw . For me it is fine. Thanks a lot @brunopostle for your guidance on setting proper checks in CI pipeline.
    Cheers!
    I propose marking all the PR's as drafts, and then share the following, to expliciting ask the PR's authors if their PR is ready to be pulled.
    Thoughts?
    Bleeding Edge Testing Branch – Contributor Expectations
    TL;DR: If your PR is ready to be pulled into the main branch, please click the “Ready for review” button.
    We’re trying something new to keep great contributions from going stale.
    🧭 The Problem
    Many excellent PRs are submitted by contributors, but core maintainers have limited time for timely reviews. As a result, PRs often sit unmerged, contributors lose momentum, and valuable work risks being forgotten.
    🛠️ The Solution: bleeding_edge Branch
    We’ve created a bleeding_edge branch that automatically merges all PRs marked as ready.
    “Ready” simply means the author has reviewed their own work and believes it’s fit for production.
    • All incoming PRs will initially be marked as Draft.
    • When your PR is ready, just click “Ready for review”.
      • If you're a returning contributor, and already know of this approach, you can also just say in your PR comments that your PR is ready to be pulled.
    • Your PR will then be automatically merged into the bleeding_edge branch.
    • Power users can install this weekly build to test multiple PRs together, helping catch issues earlier and reducing the load on core developers.
    👉 Download bleeding edge builds
    This approach allows us to:
    • Keep contributions fresh
    • Accelerate feedback loops
    • Empower the community to help stabilize new features
    Thanks for helping make this project better.
    falken10vdlsteverugi
    where is the active link please?
    I was under the impression the process would be the same as the 'unstable' one
    EDIT
    OK it's here:
    EDIT 2
    @falken10vdl FYI contrary to what indicated in the list of merged PR #7077 doesn't seem to be implemented:
    thanks
  • @steverugi Weird. I just tried it:
    What OS are you using? I am using Linux.
    Cheers!
    @falken10vdl
    I was looking for PR #7077: Add mass and time unit to new project wizard panel
    windows
    @steverugi Sorry. I think the windows build after I tried to remove DRAFT PRs did not work as expected.
    I have removed BonsaiPR Weekly Build - 2025-10-14.
    Can you please try with BonsaiPR Weekly Build - 2025-10-13.? https://github.com/falken10vdl/bonsaiPR/releases/tag/v0.8.4-alpha251013
    Cheers!
    steverugi
    I believe the automation chain is now working properly. I just run it and hopefully you will see new branches every sunday.
    This is the latest:
    https://github.com/falken10vdl/bonsaiPR/releases/tag/v0.8.4-alpha251021
    with these PRs added to enjoy testing!
    Cheers!
    theoryshawsteverugiMas
  • @theoryshaw That is really cool!
    Thanks!
  • Just FYI, I changed a number of PR's to drafts, and shared the following blurb...
    Hi @
    Just an fyi, i changed this PR to a 'draft'.
    Logic here: https://github.com/falken10vdl/bonsaiPR/blob/main/PR_workflow.md
    Originally discussed here and here.
  • I don't know if this is a good idea to include in the bleeding edge build, but it would be useful to know if a PR is failing to merge into bleeding edge because it is conflicting with other PR's or if it fails to merge with the head of vanilla Bonsai main because it is stale. People could be confused if their PR is marked in edge as failing to merge, but as far as they are concerned, there are no conflicts in their up-to-date local repo.
    theoryshaw
  • edited November 2025
    Good poibt @sjb007 ! Let me add some automation to check each pr individually against the head and add that information. Most of them probably are fine to merge against the head but it is just a conflict with some other pr inthe same code area. I have actually combined a few of my PRs to avoid this issue and have them all merged... ;)
    Cheers!
    sjb007
