How to use the 3-Point Arc in Profile editing
Hello,
Does anyone knows how to use the 3-Point Arc command when editing a Profile?
It says to first select three vertices. When I do, no arc is created.
Thanks
  • edited October 2025
    @RaphaëlVouilloz
    see if this helps:
    you can use the object as IfcArbitraryClosedProfileDef
    make sure you have filled (select all vertices and press 'F') it before
    theoryshawRaphaëlVouillozfalken10vdlwmi
  • MasMas
    edited October 2025
    @RaphaëlVouilloz
    subdivide the edges
    grab the middle point and adjust the position
    select points/edges are not needed (if you have subdivided all edges) and press "CTRL+X" to delete this points/edges
    Extruded profil in freecad
  • Ok now I get it, I have to select the two edges and not the three vertices only. Thanks to both of you for the videos!
    Mas
  • MasMas
    edited October 2025
    I think if you are selecting the points, the connected edges (between the points) should be also be selected, otherwise it could be that you have doubles (duplicated points) in it. To solve this press "TAB" for editmode--> select all --> in "vertexmode", right mousebutton--> merge vertices --> by distance
    @RaphaëlVouilloz
    when you select vertices you automatically select the edges connecting them
  • You are both right, but I was trying with three isolated vertices, as I am used to with points in sketch environments like FreeCAD.
