Convert .md --> .svg (and also .pdf and .html)
A windows .bat script to convert .md → .html → .pdf → .svg
https://hub.openingdesign.com/OpeningDesign/Utility_Apps/src/branch/main/Bat/md_to_html_to_pdf_to_svg
Here's the latest evolution of the .bat file that converts a
.mdto.svghttps://hub.openingdesign.com/OpeningDesign/Utility_Apps/src/branch/main/Bat/convert_md_to_svg_html_only
For example, was able to quickly convert this markdown file to these SVG files.
I then used Bonsai to compose these referenced SVG's on to a sheet. Here's the IFC file.
Did you notice the weirdness with lowercase "L" and capital "I" weighting and italicization?
Also a number of tables are rendering as text instead of as tables. "Suspended ceilings and Mechanical Systems" is the first one.
Otherwise... neat!
Cool, though this needs to be a python module/wheel, and bonsai needs to run it for IFC document references that point to markdown files - so all project documentation is collected/referenced by the IFC, and the SVG/HTML can be regenerated by bonsai when the markdown updates. The generated SVG should live in sub folders as drawings are currently.
I did. I've noticed that happens with a few html to pdf converters.
sounds cool to me. ;)
Oh, So this is happening here:
and the svg looks good in browsers? How peculiar!
I'm not 100% sure though.
