Bonsai, align IFC reference image
There is a some method to align reference image to grids in Bonsai? I've image from scanned project.
  • edited November 2025
    @LesarStache
    do you mean scale it up to actual dimensions? I
    1. use the Measure tool to find a known dimension (best a long one) on the plan
    2. use the scale tool and
    3. press '=' to enter in formula mode
    4. apply Dexpected/Dmeasured (the length of what indicated in the plan divided by the measured length).
    Once scaled I use G to move it 'eyeballing' its position, AFAIK the only reference you have in an image is its center.
    Hopefully someone with better skills here will add something to it
  • For scaling the ifcreference image maybe you can use pr
    https://github.com/IfcOpenShell/IfcOpenShell/pull/7207
    See https://community.osarch.org/discussion/comment/26722#Comment_26722
    You can test it if you load the "bleeding edge addon (bonsaipr)":
    https://github.com/falken10vdl/bonsaiPR/releases
    Cheers!
  • @falken10vdl nice one, I wonder if for just scaling the division method would be quicker?
    Thanks
  • @steverugi yes, it is another optionn :)
    You can shift right click to set the position of blender cursor and then change the povot point to cursor in the top middle of your screen.
  • @JanF
    Sure, but I don't think you can 'grab' it from a specific point and snap it onto something as you would with the traditional G > B sequence (if the intention is to align the image with a grid line for instance), maybe because the image is an 'empty'?
    But yes, either from top menu or by using " . " to set the pivot point from 3D cursor as reference for transformations, allows for scaling/rotating from a specific point.
    Thanks
    PS just found out that origin can be 'tweaked' by using its offset..
