[solved] IfcTester IFC 4.3_ADD2 support question
Hi,
is IFC 4.3_ADD2 supported in IfcTester web app? When trying to load an IFC 4.3 file created in Bonsai, I get this error:
I have no problem running the IDS testing against IFC 4.3 files inside of Bonsai, so this seems like a weird to me. Does anyone know whether the 4.3 schema should be supported by web IfcTester?
Tom
When searching a bit on GitHub I found out the issue is already been worked on: https://github.com/IfcOpenShell/IfcOpenShell/pull/7593
Does anyone know how long it takes for the fixes to be published on the IfcTester.org site?
Currently IfcTester.org uses stable versions so we'll wait for the next stable release. Now that I'm slowly betting back into the swing of things I'll need to decide on a date, but still feeling my way around and seeing what's changed.
Thanks for the information.
