[solved] IfcTester IFC 4.3_ADD2 support question
edited January 23 in General
Hi,
is IFC 4.3_ADD2 supported in IfcTester web app? When trying to load an IFC 4.3 file created in Bonsai, I get this error:
I have no problem running the IDS testing against IFC 4.3 files inside of Bonsai, so this seems like a weird to me. Does anyone know whether the 4.3 schema should be supported by web IfcTester?
Tom
  • When searching a bit on GitHub I found out the issue is already been worked on: https://github.com/IfcOpenShell/IfcOpenShell/pull/7593
    Does anyone know how long it takes for the fixes to be published on the IfcTester.org site?
  • Currently IfcTester.org uses stable versions so we'll wait for the next stable release. Now that I'm slowly betting back into the swing of things I'll need to decide on a date, but still feeling my way around and seeing what's changed.
    semhustej
  • Thanks for the information.
