Dasu - layout & print web app
Hi, I have been working on a web app for laying out and printing drawings, actually my new mate Claude and I have been working on it :)
The problem I had was putting together drawing sheets on my secured locked-down work computer, I was using PowerPoint, there were some limitations! so, I pasted a mockup of what I thought the UI could look like into Claude last weekend and got obsessed. See the link for a proof-of-concept https://github.com/4nigel/dasu
I see an opportunity for this to integrate with Bonsai, as mentioned in the road map file.
It's my first attempt at a web app and first use of Github so please excuse any noobism
theoryshawduarteframossteverugiMassimofalken10vdlDimitriszoomerwalpadpszlJavier
  • posting my promote icon was not enough :)
    Guys please check what @Nigel is sharing here, it's awesome!
    Devs, kindly consider it to handle our web layout editor, we can bridge the current gap we have when Bonsai goes into SVG via Inkscape or similar for its output.
    Pretty please?
    Thanks
    Nigeltheoryshawzoomerwalpaduarteframos
  • Very interesting stuff!
    I see a lot of value also for modifying hatches and lines without the need to modify the css by hand
    theoryshawRoel
  • Awesome!
    Here's your first pull request. :)
    https://github.com/4nigel/dasu/pull/1
    prepare for the onslaught. ;)
    Nigel
  • edited March 21
    WTH !
    Looks so cool.
    And even seems to work in Safari ....
    Nigelsteverugiduarteframos
  • Here's another one :)
    https://github.com/4nigel/dasu/pull/2
    This project will be interesting to see where it goes.
    It will be interesting to see where the 'architecture' of this project will go--especially if only novice programmers, such as myself, are the only ones contributing. It'll be a fun to see it play out.
    Although I do hope more experienced coders provide their insight... but i know that bandwidth is tiny nowadays with the onslaught of vibers out there.
    steverugi
  • edited March 22
    I started by doing a mock-up of what I thought the interface should look like, pasted that into Claude told it what I wanted to be able to do and why, along with some rules like FOSS including any dependencies as well as doing everything the 'typical way' and avoiding going down rabbit holes. I was really surprised at the first iteration that came back, many buttons were clickable, some even did basic stuff like grids and paper size. If Ryan calls himself a novice, then I am definitely a noob but like any design work the better the brief (knowing what you want, why you want it and what you can afford), the better the outcome.
    steverugifalken10vdltheoryshawwalpazoomer
  • edited March 22
    The following AI-assisted proposal explores aligning with how Bonsai structures its assets. It also explores replacing the .bprint format with a distributed set of files that would be easier to version track with Git — with the aim, basically, of making the workflow as distributed-friendly as possible.
    Thoughts?
    Proposal Here
    # Proposal: A Shared Open Project Format for Bonsai and Dasu
    Background
    Dasu is a browser-based drawing sheet layout tool. It lets you compose drawings from Bonsai BIM, DXF, PDF, SVG, and raster images into print-ready sheets — entirely in the browser, with no install or subscription required. It includes a local bridge server that receives live SVG pushes from Blender/Bonsai as you work.
    Bonsai (formerly BlenderBIM) is the Blender-based open-source BIM authoring tool built on IfcOpenShell. Among its many capabilities, it manages drawing sets: it generates SVG drawings from camera views, assembles them into sheet layouts, and stores all of this in the IFC file and on disk.
    At present, these two tools work alongside each other but maintain separate, incompatible project structures. This proposal describes a path toward a shared open format that would let both tools — and future tools — read and write the same project folder without conflict.
    The Problem
    Dasu's current format
    Dasu currently saves everything into a single .bprint file: a JSON blob containing Fabric.js canvas state for all sheets, embedded or referenced assets, app preferences, and project metadata. This works for single-user workflows but has real limitations:
    • Not git-friendly. A single JSON blob means every save produces a large, unreadable diff. Embedded base64 images make it worse.
    • Not interoperable. No other tool can read or write a .bprint file.
    • Duplicates what Bonsai already knows. Sheet names, drawing scales, IFC paths, and project metadata are all stored in the IFC file by Bonsai. Dasu maintains its own copy, which drifts out of sync.
    • Monolithic. Adding a dimension on one sheet touches the same file as changing the titleblock on another, making collaborative merges messy.
    Bonsai's existing structure
    Bonsai already writes a well-considered folder structure:
    project-root/
      model.ifc
      drawings/       ← SVG drawings generated from camera views
        assets/       ← per-drawing resources (stylesheets, markers, symbols, patterns)
      layouts/        ← editable sheet layout SVGs (source)
        assets/       ← view title templates, symbols
        titleblocks/  ← titleblock SVG templates
      sheets/         ← compiled output SVGs (built from layouts)
    The IFC file itself is the manifest: sheets are IfcDocumentInformation entities, drawings are IfcAnnotation entities, and relationships between them are stored as IfcDocumentReference entries. This is already an open, standardised structure.
    The question is: can Dasu join this structure rather than sit alongside it?
    The Proposal
    We propose that Dasu adopt Bonsai's existing folder and file conventions as its primary project format. Instead of a single .bprint file, a Dasu project is a folder on disk — the same folder as the Bonsai project.
    Folder structure (no changes to Bonsai's conventions)
    project-root/
      model.ifc                     ← source of truth for sheet/drawing structure
      drawings/                     ← Bonsai writes; Dasu reads
        FLOOR PLAN.svg
        SECTION-A.svg
        assets/                     ← per-drawing resources referenced in EPset_Drawing
          default.css               ← Stylesheet
          markers.svg               ← Markers
          symbols.svg               ← Symbols
          patterns.svg              ← Patterns
          shading-styles.json       ← ShadingStyles
      layouts/                      ← both Bonsai and Dasu read and write
        A-001 - Floor Plan.svg      ← editable layout SVG
        A-002 - Elevations.svg
        assets/
          view-title.svg
        titleblocks/
          A3-LANDSCAPE.svg
      sheets/                       ← compiled output; neither tool edits this directly
        A-001 - Floor Plan.svg      ← built by SheetBuilder from layouts/
      images/                       ← raster content placed in Dasu (new)
      .dasu/                        ← thin sidecar for Dasu-specific state (new)
        canvas.json
        prefs.json
    The only new directories are images/ and .dasu/. Everything else already exists.
    The layout SVG as the shared working file
    Bonsai's layout SVGs already use a clean, structured format with data-type attributes:
    <svg xmlns="http://www.w3.org/2000/svg">
      <g data-type="titleblock">
        <image xlink:href="titleblocks/A3-LANDSCAPE.svg"
               x="0" y="0" width="420mm" height="297mm"/>
      </g>
      <g data-type="drawing"
         data-id="{reference_id}"
         data-drawing="{IfcAnnotation.GlobalId}">
        <image data-type="foreground"
               xlink:href="../drawings/FLOOR PLAN.svg"
               x="30mm" y="30mm" width="340mm" height="220mm"/>
        <image data-type="view-title"
               xlink:href="assets/view-title.svg"
               x="30mm" y="252mm"/>
      </g>
    </svg>
    Dasu would read and write this format directly. When Dasu places a drawing on a sheet, it writes a <g data-type="drawing"> group. When Bonsai reads the layout, it sees the same group. Both tools edit the same file without conflict, because each tool owns its own content type.
    Content that has no IFC equivalent (user-placed annotations, DXF imports, raster images, non-Bonsai SVGs) would be written into a <g data-type="dasu-overlay"> group that Bonsai ignores gracefully.
    The IFC file as manifest
    Dasu would read sheet and drawing metadata directly from the IFC, rather than maintaining its own copy:
    • Sheet list, names, paper sizes, revision metadataIfcDocumentInformation (Scope=SHEET)
    • Drawing propertiesIfcAnnotation (ObjectType=DRAWING) + EPset_Drawing
    • Which drawings are on which sheetIfcDocumentReference relationships
    • Project-level pathsBBIM_Documentation property set on IfcProject
    This means when a Bonsai user renames a sheet or updates a revision, Dasu sees it immediately on next open — no sync required.
    EPset_Drawing — what Dasu would read
    Each drawing carries a property set that describes not just its scale and projection, but also the paths to all the assets used to render it. Dasu would read all of these:
    Property What it is How Dasu uses it
    Scale Numeric denominator (e.g. "100") Scale label, dimension calculations
    HumanScale Display string (e.g. "1:100") Title block, view title
    TargetView Projection type (PLAN_VIEW, SECTION_VIEW, etc.) Display hint, filtering
    HasLinework Boolean Whether to expect linework in the SVG
    HasAnnotation Boolean Whether annotations are embedded in the SVG
    HasUnderlay Boolean Whether an underlay layer is present
    Include / Exclude Comma-separated IFC GUIDs Element filter — which model elements are visible
    GlobalReferencing Boolean Whether the drawing uses global coordinates (sections/elevations)
    Stylesheet Path to .css file in drawings/assets/ Base visual style applied to the drawing SVG
    Markers Path to markers SVG in drawings/assets/ Arrowheads, endpoint symbols, line terminators
    Symbols Path to symbols SVG in drawings/assets/ Door tags, window tags, section marks, etc.
    Patterns Path to patterns SVG in drawings/assets/ Hatch patterns for materials and fills
    ShadingStyles Path to shading style definitions in drawings/assets/ Library of available shading presets
    CurrentShadingStyle Name of the active shading preset Which preset from ShadingStyles is currently applied
    Metadata Comma-separated metadata keys Custom title block fields
    The asset paths (Stylesheet, Markers, Symbols, Patterns, ShadingStyles) all resolve relative to the IFC file location, and the files themselves live in drawings/assets/. This is important for Dasu: rather than maintaining its own parallel style system, it can read and honour the styles Bonsai has already defined. Dasu-specific overrides (per-IFC-class colour, lineweight, visibility) would layer on top of these base styles and be stored in .dasu/canvas.json — only the delta, not a full replacement.
    The .dasu/canvas.json sidecar
    A small sidecar file stores only what cannot live in either the IFC or the layout SVG: Fabric.js-specific state that Dasu needs to reconstruct the canvas but that has no standard representation elsewhere.
      "version": "0.5.0",
      "prefs": {
        "nudgeMm": 1,
        "gridMm": 10,
        "snapEnabled": true,
        "pdfRes": 2
      "objects": {
        "{IfcAnnotation.GlobalId}": {
          "_bonsaiStyleMap": {
            "IfcWall": { "stroke": "#000000", "strokeWidth": 0.5 },
            "IfcSlab": { "stroke": "#000000", "strokeWidth": 0.25 }
          "_dxfLayerMap": {
            "WALLS": { "visible": true, "color": "#000000" }
          "_crop": { "t": 0, "r": 0, "b": 0, "l": 0 }
    Sheet names, paper sizes, positions, scales — all absent here because they live in the IFC or the layout SVG. The sidecar is genuinely thin.
    Sheets are a build artefact
    The sheets/ directory is the compiled output of SheetBuilder.build(). Neither Dasu nor the user edits it directly. It is produced from layouts/ on demand — either by Bonsai's "Build Sheet" operator, or triggered by Dasu via the bridge server. This means sheets/ can go in .gitignore, the same way compiled build output does in software projects.
    Why this is better for collaboration
    Git-friendly by design
    git diff layouts/A-001\ -\ Floor\ Plan.svg   ← sheet layout changed
    git diff drawings/FLOOR\ PLAN.svg            ← Bonsai regenerated a drawing
    git diff .dasu/canvas.json                   ← style overrides or crop changed
    git diff model.ifc                           ← sheet structure or metadata changed
    Each concern diffs independently. Changing a dimension annotation on one sheet touches only that sheet's layout SVG. Adding a drawing to another sheet touches only that sheet's file, plus model.ifc for the relationship. No single blob accumulates all changes.
    Binary files (images/*.png, PDFs) are isolated in their own directory, making .gitattributes rules for Git LFS straightforward:
    images/* filter=lfs diff=lfs merge=lfs -text
    *.pdf   filter=lfs diff=lfs merge=lfs -text
    Decentralised workflow
    Because the format is a plain folder of standard files, teams can:
    • Use any git host (GitHub, GitLab, Forgejo, Gitea) with no special tooling
    • Work on different sheets in parallel branches with clean merges
    • Review sheet changes in pull requests by diffing SVG and JSON files
    • Roll back to any previous state of any individual sheet
    • Have Bonsai users and Dasu users collaborating on the same repo without a shared server
    No proprietary lock-in
    The format is: IFC (ISO 16739), SVG (W3C), JSON (ECMA-404), and a folder. Any tool that can read these can participate. The .dasu/canvas.json sidecar uses no proprietary encoding — it is plain JSON that any developer can parse.
    What would need to change
    In Dasu
    • Replace cmdOpen / cmdSave (single-file) with cmdOpenFolder / cmdSaveFolder (directory-based)
    • Read sheet and drawing metadata from the IFC file rather than from .bprint
    • Write canvas positions into the layout SVG format rather than a Fabric.js JSON blob
    • Use window.showDirectoryPicker() in Chrome/Edge; fall back to the bridge server for Firefox and for Blender-integrated workflows
    • Remove the .bprint format entirely — no migration path, clean break
    In Bonsai
    Potentially nothing, or very little. Bonsai already owns layouts/, drawings/, sheets/, and model.ifc. The proposal asks Dasu to conform to Bonsai's conventions, not the other way around.
    One possible addition: a small extension to the layout SVG schema to formally define data-type="dasu-overlay" as a recognised but tool-agnostic content group, so future tools know to preserve it rather than strip it. This could be a one-line addition to Bonsai's SVG schema documentation.
    Open questions for the community
    1. Layout SVG as shared working file — Is it appropriate for Dasu to write directly to the layout SVG, or should Bonsai remain the sole writer of that file? An alternative is for Dasu to maintain its own sidecar layout alongside Bonsai's, with a merge step.
    2. IFC read in the browser — Reading model.ifc from a browser requires an IfcOpenShell WASM build or delegating to the bridge. The bridge is the pragmatic path for now. Is there appetite in the community for a lightweight browser-side IFC reader focused on document/sheet metadata only?
    3. data-type="dasu-overlay" formalisation — Should this be a documented extension to the Bonsai layout SVG schema? Or should Dasu-placed non-IFC content live entirely in a separate sidecar SVG per sheet?
    4. Titleblock templating — Bonsai uses Mustache-style templating in titleblock SVGs ({{Scale}}, {{Name}}, etc.). Dasu currently generates title blocks programmatically. Should Dasu adopt the same template format so both tools use the same titleblock files?
    5. The bridge server's role — In this architecture, the bridge becomes the primary I/O layer (file read/write, IFC parsing, sheet building). Is this the right direction, or should the browser do more directly via the File System Access API?
    6. .dasu/ in version control — Should .dasu/canvas.json be committed (so collaborators share canvas layout state) or gitignored (so it's local to each user, like an IDE's .vscode/ folder)? The answer probably depends on workflow.
    Summary
    Current Proposed
    Primary format .bprint (single JSON blob) Project folder (IFC + SVGs + sidecar)
    Sheet manifest Duplicated in .bprint IFC file (single source of truth)
    Layout files Fabric.js JSON Bonsai layout SVG format
    Git-friendliness Poor (binary blob, no per-sheet diffs) Good (text files, per-sheet diffs, LFS for binaries)
    Bonsai interop Bridge only (live push) Shared folder (continuous)
    Portable sharing .bprint file Zip the folder, or git archive
    New standards required None None (IFC, SVG, JSON)
    This is not a proposal to build something new. It is a proposal for Dasu to stop maintaining a parallel structure and instead join the one Bonsai has already built — using open standards that any future tool can participate in.
    Feedback and questions welcome.
    Dasu is free and open-source. Source: github.com/openingdesign/dasu
    brunopostlewalpaNigelsteverugizoomerDimitrisSamppa
  • @theoryshaw the proposal was a lot of reading for me, I had to get my AI to help me 😉
    this is a really cool idea, and I have two other ideas to add to it, see my svg that I made in Dasu with a Claude diagram
  • edited March 23
    @Nigel Cool. Can you have AI print out a proposal writeup similar to the one I posted above. Will help me understand a little more.
  • Hi @theoryshaw the attached doc sums it up well. You will see I had a thought about Dasu outputting Ifc 2D documentation
  • @Nigel nice, i think we're getting somewhere!
    I've modified the proposal to incorporate your additional development 'paths', and refined a few other ideas, and added a few more ideas, as well
    This is fun. :)
    Proposal Here
    The following AI-assisted proposal explores aligning with how Bonsai structures its assets. A parallel path alongside the .bprint format that explores a distributed set of files that would be easier to version track with Git — with the aim, basically, of making the workflow as distributed-friendly as possible.
    A response from community member Nigel has been incorporated below, which refines the proposal considerably — in particular introducing a three-pathway framework that preserves .bprint for standalone use cases rather than retiring it outright.
    Background
    The Problem
    project-root/
      model.ifc
    Design Strategy: Adopt Conventions, Not Assumptions
    The guiding principle for this proposal — especially in these early stages — is to adopt Bonsai's conventions as fully as possible, and diverge only when real-world friction makes it necessary.
    Bonsai has already solved hard problems through years of actual use: token naming, file structure, IFC entity relationships, asset path conventions, status vocabulary. Adopting these wholesale means Dasu inherits those design decisions without having to justify them from scratch. It also gives Dasu an immediate, credible value proposition for the OSArch community: it works natively with Bonsai projects from day one.
    There is also a practical argument against premature abstraction. It is not possible to design a good platform-agnostic standard in the abstract. The right time to generalise is when there is real friction — a second tool that does things differently and needs to interoperate. Building toward an imagined standard before that point usually produces the wrong abstraction.
    The important distinction is between conventions and assumptions:
    • Conventions — token names, folder structure, status values, file formats, template schemas. These are safe to adopt wholesale and are shared across all three paths.
    • Assumptions — that IFC always exists, that the bridge is always running, that Blender is the source of all drawings. These must remain Path 2 concerns, not baked into the core of Dasu.
    The three-pathway framework enforces this boundary. For example: {{Name}} and {{Identification}} are Dasu's token names across all paths — but in Path 1 they are populated from Dasu's own sheet metadata, not from an IFC file. The vocabulary is shared; the data source is path-dependent. That is the right level of coupling.
    Where divergence will eventually be needed — the likely candidates are things Bonsai doesn't need to handle because it lives inside Blender: multi-source sheet composition (DXF, PDF, and rasters alongside IFC drawings), browser-native UX patterns, the crop/viewport concept, and non-IFC projects. These are the areas where Dasu will eventually need its own conventions. By the time those needs arise, there will be real-world experience to design from rather than speculation.
    The Three-Pathway Framework
    Rather than a single mandatory format, the proposal recognises three distinct usage contexts. The folder-based format is the right long-term direction — but it is not the only format, and .bprint is not retired.
    Pathway Name Characteristics
    Path 1 Standalone / locked-down No bridge, no IFC, .bprint format, any machine
    Path 2 Bonsai-integrated Bridge required, IFC manifest, folder format, git-friendly
    Path 3 IFC import (read-only) — later phase Bridge optional, IFC read-only input, .bprint output
    Shared infrastructure across all three paths:
    - SmartText tokens — PascalCase, Bonsai-compatible
    - dasu-overlay SVG group — Dasu namespace, Bonsai ignores gracefully
    - Sidecar concept — .bprint is a fat sidecar; .dasu/ is a thin sidecar
    - PDF / SVG / Print output
    Note on .bprint: Path 1 users — including users on locked-down government machines where window.showDirectoryPicker() requires explicit IT permissions — depend on the zero-dependency .bprint workflow. .bprint is a permanent first-class format for Paths 1 and 3, not a stepping stone to be retired. Both formats coexist permanently.
    The Proposal (Path 2: Bonsai-integrated)
    We propose that Dasu adopt Bonsai's existing folder and file conventions as its Path 2 project format. A Path 2 project is a folder on disk — the same folder as the Bonsai project.
    project-root/
        FLOOR PLAN.svg
        SECTION-A.svg
        assets/
          view-title.svg
        titleblocks/
          A3-LANDSCAPE.svg
        canvas.json
        prefs.json
    Bonsai's layout SVGs already use a clean, structured format with data-type attributes. The key principle is that each tool owns clearly named groups and never writes into the other tool's groups:
      </g>
      </g>
        <!-- Dasu-placed annotations, DXF imports, non-IFC content -->
      </g>
    </svg>
    Ownership rules:
    SVG group Ownership rule
    data-type="titleblock" Bonsai owns — reads and writes
    data-type="drawing" Bonsai owns — reads and writes
    data-type="dasu-overlay" Dasu owns — reads and writes. Bonsai preserves but ignores
    Position of Bonsai drawings Dasu never writes x/y into Bonsai-owned groups. Position overrides go into .dasu/canvas.json only
    Round-trip safety dasu-overlay is a formally documented, reserved group name — Bonsai preserves it, Inkscape passes it through, other tools ignore it gracefully
    Content that has no IFC equivalent (user-placed annotations, DXF imports, raster images, non-Bonsai SVGs) lives in the dasu-overlay group and is invisible to Bonsai.
    Conflict resolution by path:
    Path Rule
    Path 1 No IFC — Dasu meta is source of truth
    Path 2 IFC wins on conflict with Dasu meta
    Path 3 IFC read-only input — no write-back
    The asset paths all resolve relative to the IFC file location, and the files themselves live in drawings/assets/. Dasu-specific overrides (per-IFC-class colour, lineweight, visibility) layer on top of these base styles and are stored in .dasu/canvas.json — only the delta, not a full replacement.
    A small sidecar file stores only what cannot live in either the IFC or the layout SVG. The discipline is keeping it thin: if something can live in the IFC or the layout SVG, it must not also live in the sidecar.
      "version": "0.5.0",
      "prefs": {
        "nudgeMm": 1,
        "gridMm": 10,
        "pdfRes": 2
      "objects": {
          "_dxfLayerMap": {
    What lives where:
    Content type Where it lives
    Fabric.js display state Object caching, canvas zoom — sidecar only
    Per-drawing deltas Style overrides, DXF layer maps, crop bounds — keyed by IfcAnnotation.GlobalId
    User preferences Grid, snap, PDF resolution — sidecar only
    Sheet name / revision / status IFC (Path 2) or _blankMeta (Path 1) — not in sidecar
    Sheet names, paper sizes, positions, scales — all absent here because they live in the IFC or the layout SVG. Note the key change for Path 2: Fabric object IDs are replaced by IfcAnnotation.GlobalId as the per-drawing key, which is stable across sessions.
    Should .dasu/canvas.json be committed to git? Yes, by default. It contains layout decisions that affect what everyone sees on the sheet — it is not the same as .vscode/ which is truly personal. Teams can choose to gitignore it if they prefer local-only canvas state.
    The sheets/ directory is the compiled output of SheetBuilder.build(). Neither Dasu nor the user edits it directly. It is produced from layouts/ on demand — either by Bonsai's "Build Sheet" operator, or triggered by Dasu via the bridge server. sheets/ should go in .gitignore, the same way compiled build output does in software projects.
    Binary files are isolated in their own directories, making .gitattributes rules for Git LFS straightforward:
    *.ifc   filter=lfs diff=lfs merge=lfs -text
    Note: model.ifc should also go to Git LFS for larger projects — IFC files commonly reach 50–200 MB.
    What already exists (in Bonsai / IfcOpenShell)
    The following are not Dasu work items — they already exist in Bonsai. Dasu's job is to consume them, not rebuild them:
    Asset Where it lives What Dasu needs to do
    SVG titleblock templates with {{Token}} fields layouts/titleblocks/ in the Bonsai project Read and render these rather than generating its own
    Sheet metadata schema (IfcDocumentInformation) model.ifc Read via bridge
    Drawing metadata schema (EPset_Drawing) model.ifc Read via bridge
    Per-drawing assets (Stylesheet, Markers, Symbols, Patterns) drawings/assets/ Resolve paths and apply
    Layout SVG format (data-type groups) layouts/*.svg Parse and write to
    In Dasu — what needs to be built
    The honest sequencing, with no items marked done prematurely:
    Task Description Stage
    Bridge IFC reader Read IfcDocumentInformation + EPset_Drawing from model.ifc via bridge — prerequisite for almost everything else in Path 2 Near term
    Token alignment Replace Dasu's dot-notation tokens with Bonsai's IFC attribute names outright (see table below). Existing user titleblocks will need updating — no compatibility shim. Near term
    cmdOpenFolder Add alongside existing cmdOpen — opens a Bonsai project folder via bridge or showDirectoryPicker() Near term
    .dasu/ sidecar write Once folder open works, write thin JSON sidecar keyed by IfcAnnotation.GlobalId rather than Fabric object IDs Near term
    Layout SVG read Parse layouts/*.svg to reconstruct sheet canvas from Bonsai-placed drawings Near term
    dasu-overlay write Write Dasu annotations into <g data-type="dasu-overlay"> group in layout SVG Near term
    .bprint migration tool Convert existing .bprint files to folder format via bridge Near term
    showDirectoryPicker() Chrome/Edge native directory access without bridge Medium term
    IFC write-back Write sheet positions and paper size back to model.ifc via bridge Later
    Token mapping — Dasu → Bonsai
    Bonsai builds its token data directly from IFC attribute names via get_info(). Sheet fields are prefixed with Sheet. The full replacement:
    Current Dasu token Bonsai token IFC source
    {{sheet.name}} {{SheetName}} IfcDocumentInformation.Name
    {{sheet.id}} {{SheetIdentification}} IfcDocumentInformation.Identification
    {{description}} {{SheetDescription}} IfcDocumentInformation.Description
    {{revision}} {{SheetRevision}} IfcDocumentInformation.Revision
    {{sheet.status}} {{SheetStatus}} IfcDocumentInformation.Status
    {{issue.date}} {{SheetLastRevisionTime}} IfcDocumentInformation.LastRevisionTime
    {{purpose}} {{SheetPurpose}} IfcDocumentInformation.Purpose
    {{sheet.scale}} {{Scale}} EPset_Drawing.HumanScale (computed)
    {{drawn.by}} {{DrawnBy}} Custom pset (no IFC equivalent)
    {{checked.by}} {{CheckedBy}} Custom pset (no IFC equivalent)
    {{discipline}} {{Discipline}} Custom pset (no IFC equivalent)
    {{project.name}} {{ProjectName}} IfcProject.Name or IfcSite.Name
    {{project.address}} {{ProjectAddress}} IfcSite address (no direct IFC attribute)
    {{date}} {{Date}} Computed at render time
    {{year}} {{Year}} Computed at render time
    Tokens with no IFC equivalent (DrawnBy, CheckedBy, Discipline, ProjectAddress) would be sourced from a custom property set or from Dasu's own sheet metadata — to be confirmed with the Bonsai team.
    Further alignments with Bonsai conventions
    Beyond token names, this proposal adopts several other Bonsai conventions outright:
    Sheet status values — Bonsai stores status in EPset_Status.Status as a free-text field on IfcDocumentInformation. There is no fixed Bonsai enum. Dasu proposes adopting the following common construction industry values (aligned with IFC convention and industry practice) and storing them in the same pset:
    Status Meaning
    DRAFT Work in progress
    FOR REVIEW Issued internally for review
    FOR APPROVAL Submitted for client/authority approval
    FOR CONSTRUCTION Issued to contractor
    FOR INFORMATION Reference only
    AS-BUILT Reflecting constructed works
    SUPERSEDED Replaced by a later revision
    View title template — Dasu will adopt Bonsai's view-title.svg directly from layouts/assets/ rather than generating its own. The template uses three tokens: {{Identification}}, {{Name}}, {{Scale}}. No Dasu-specific tokens are added to the view title.
    Paper size from titleblock SVG — Bonsai does not store paper size as a separate IFC property. Sheet dimensions are inferred from the titleblock SVG's width and height attributes. Dasu will do the same — paper size is a property of the titleblock file, not of the sheet record.
    Target view vocabulary — Dasu will use Bonsai's EPset_Drawing.TargetView values verbatim for labelling and filtering drawings:
    Value Label
    PLAN_VIEW Plan
    SECTION_VIEW Section
    ELEVATION_VIEW Elevation
    REFLECTED_PLAN_VIEW RCP
    MODEL_VIEW Model
    Titleblock token set — Bonsai's titleblock templates (A1, A2, A3) use {{Name}}, {{Identification}}, and {{Revision}} as their core tokens, rendered via pystache from IfcDocumentInformation.get_info(). Dasu will render these templates using the same data source and the same token names.
    In Bonsai
    One possible addition worth raising with the Bonsai team: formally document data-type="dasu-overlay" as a reserved-but-ignored group name in the layout SVG schema, so future tools know to preserve it rather than strip it. One line in Bonsai's documentation would suffice.
    1. data-type="dasu-overlay" formalisation — This proposal assumes dasu-overlay will be formally documented as a reserved, tool-agnostic group name in the Bonsai layout SVG schema. Is the Bonsai team agreeable to this? A one-line addition to the schema documentation would be sufficient.
    2. Status values — Since EPset_Status.Status is free-text in IFC, there is no canonical list to adopt. The values proposed above reflect common industry practice — are they the right set? Are there values missing or that should be renamed?
    3. IFC read in the browser — Reading model.ifc from a browser requires an IfcOpenShell WASM build or delegating to the bridge. The bridge is the pragmatic path for now. Is there appetite in the community for a lightweight browser-side IFC reader focused on document/sheet metadata only?
    4. The bridge server's role — In Path 2, the bridge becomes the primary I/O layer (file read/write, IFC parsing, sheet building). Is this the right direction, or should the browser do more directly via the File System Access API for users who have it available?
    5. Path 3 — clarification needed, assumed later phase — Nigel's response refers to Path 3 as "MoneyBIM IFC import", but this term doesn't correspond to any known tool or product we could identify. Our best reading is that it describes a workflow where a user imports an IFC file to extract drawing/sheet metadata without needing a full Bonsai/Blender setup — using IFC as a read-only data source to populate a .bprint project. Parsing IFC independently of the bridge would require either an IfcOpenShell WASM build or a lightweight IFC reader, which is a meaningful technical dependency. Our assumption is that this is a later phase of implementation, tackled after Path 1 and Path 2 are solid. If the community sees it differently — or if it is simpler to implement than we think — please correct us.
    Summary
    Path 1 (current) Path 2 (proposed) Path 3
    Primary format .bprint (single JSON blob) Project folder (IFC + SVGs + sidecar) .bprint output
    Sheet manifest Dasu meta IFC (single source of truth) IFC read-only
    Layout files Fabric.js JSON Bonsai layout SVG format n/a
    Git-friendliness Poor Good (per-sheet diffs, LFS for binaries) Poor
    Bonsai interop Bridge only (live push) Shared folder (continuous) IFC import
    Bridge required No Yes (filesystem proxy) Optional
    Portable sharing .bprint file Zip the folder, or git archive .bprint file
    New standards required None None (IFC, SVG, JSON) None
    This is not a proposal to build something new. It is a proposal for Dasu to grow a second, Bonsai-native mode — built entirely from standards that already exist — while keeping the standalone .bprint workflow intact for users who need it.
    Nigel
    This is fun. :)
    it sure is fun, it's now lunchtime in NZ so I'll read your update :)
    Noob question: when I update dasu.html in my own GitHub repo do I need to do a pull request? I worried I may have over-written your recent update
  • edited March 23
    No, you can push directly.
    If you push, and if your change conflicts with something that is already on github, it will let you know there's a conflict, and then you have to resolve before pushing.
    As a general rule, before i 'push', i like to make sure I 'pull' down all the recent changes.
    And also, if i plan on making a changes, i pull down before i start making changes.
    You'll get used to it. :)
    In general don't worry about overwriting something. That's what Git's great for--keeping the history of changes, and being able to revert if need be.
  • I make a PR with this proposal doc:
    https://github.com/4nigel/dasu/pull/3
    Using git will better help us 'diff' it now, as it evolves.
  • @theoryshaw MoneyBIM is my name for all the proprietary BIM apps ;)
  • ha... gotcha. Thanks, google was not helping. :)
