Addressing some core IfcOpenShell issues
Ever since the new year and AI rocking the boat, I've been thinking hard about what this means for core IfcOpenShell. IfcOpenShell has been battle-tested for ages and has put a large emphasis on correctness and reliability and it has a very strong foundation on the API and authoring. However, there are clearly areas which are lacking compared to alternatives like Web-IFC and IFC Lite. These newer libraries put a lot of emphasis on speed, re-serialisation into formats that allow scalability, and focus on the web platform which is clearly the favourite of the newer generation. These are areas where IfcOpenShell needs to play the catch-up game. There are also long standing issues which although a lot has been addressed in v0.8.0, there is still a long way to go.
This isn't to say that the interface and desktop authoring isn't important. It is still very important, but with AI, interfaces are becoming easier to build, and there is already a lot there, so it is easier to work around the rough edges even if you aren't a developer. However if the fundamental architectural issues aren't resolved, even though we have a good foundation, AI models and developers may shift focus to other solutions and all the effort we've put into the correctness and authoring experience and schema integration and so on will be wasted which'll be a real shame. I know what I'm describing here might not make much sense to users who are interacting with the interface, but I can guarantee that things like Bonsai itself wouldn't have been possible without the core of IfcOpenShell being a giant shoulder to stand on, and the more we address the core, the more opportunities open up.
In short, I strongly believe IfcOpenShell needs to become the "curl", the "ffmpeg" of the software world. A de-facto, ubiquitous swiss army knife for working with AEC data. And we're not there yet.
In an ideal world, IOS needs to have the ability to instantly open a model and perform non-geometric queries, and instantly generate a drawing of 50 models federated together on the desktop, on the web, headless, etc.
Here's a braindump of some of the core things I believe we need to develop:
- A more optimised IfcOpenShell for the web. Right now, especially with the Pyodide overhead, the load time of IOS on the web is extremely slow. This starts with crushing down the WASM library.
- Native TypeScript support for the web so we can bypass Pyodide. The big challenge here is how to still provide the full capabilities of the API that we have in Python currently.
- A "get started" framework for building a web-based viewer. Right now, we have "here's a WASM, good luck". We need documentation and bootstrap examples to get people started to build a viewer in 5 minutes with npm packages and so on.
- A desktop viewer. Right now, Blender is really not optimised for a viewer and people don't realise how fast IOS really is because Blender itself imposes a crazy overhead for loading Blender meshes. We need a way on the desktop to view 50 models for simple coordination.
- A lighter geometry library for even more speed. 90% of geometry is either a mesh or an extrusion with possible CSGs. CGAL was a step in the right direction, but further micro kernels can optimise geometry loading even further.
- Instant IFC SPF loading for non-geometric queries. Right now, ifcopenshell.open() consumes an inordinate amount of time especially for models exceeding 200MB (e.g. 20 seconds). This is unacceptable for scripting many micro services such as in CI or auditing pipelines.
- Well supported hybrid serialisations where SPF falls short (and the documented tradeoffs, e.g. anything that isn't SPF will break IfcGit very unfortunately). For example, the rocksdb implementation right now solves a lot of problems with SPF in terms of memory usage and read times, but is not well battle tested. We need to further polish these as alternative approaches. Other things to investigate are hybrids e.g. one serialisation for geometric data and another for non-geometric data, so you can split the parsing or make tradeoffs with filesize or load times, or even swap in and out data / geometry, which brings us to...
- An attempt at solving the "federation" problem. Right now, IFC datasets are atomic and we cannot cross reference between them. So if I have a cost schedule, if i want to reference an object in another model, I need to duplicate that cost schedule in every single model I'm referencing. Same with spatial structures. Same with georeferencing. Same with work schedules. Same with object types. This highly inefficient duplication and problem with workflow (e.g. someone changes the model, how do we update just the cost schedule?) needs to have an attempt at being solved. This is a tricky one.
- Support for streaming and tiling to handle large models.
- Better IfcGit exposure and maturity. IfcGit is incredible. Nothing does what it does. It needs somehow to have more exposure and advertisment.
- Performance around inverse handling on larger datasets. One of the biggest gripes with big data sets is that changing classes is very slow, adding new elements is very slow, and of course the big one ... deleting is very slow. Deletion is so slow we even have code that serialises, handles as text, then unserialises. We even have code that recreates the entire file rather than deleting. It's just... something we need to fix :)
- Making voxelisation a first class citizen for geometric analysis rather than a side tool
- Another around of maturity, testing, test suites, and fixing of IfcClash to make it the clash detection toolkit and tree selection library for geometric queries
- MCP integration, even better docs, and AI tool exposure so that people building tools are ready to build things with the IOS batteries included
- Another big stab at drawing generation. OCC's HLR renderer and Freestyle + raster renders get us to a certain point, but not without cost. How do we do better?
These are known issues, and there are already initiatives being worked on to solve them. For example, the IfcZero work, the IfcMCP and IfcQuery and IfcEdit work, the rocksdb work, the 1.0 datamodel work...
There's so much to do, but hopefully we'll move faster and with more people joining in on the fun we can build more too.
AI assisted proposal around prioritizing ifcgit as the differentiator
Moult — thanks for this writeup. The curl/ffmpeg framing is exactly right and I think the list of issues you've identified is accurate. I want to offer a perspective on how these pieces might be unified around a single strategic thread rather than tackled as parallel workstreams.
The argument in short: IFC-aware version control is the one differentiator that nobody else is building, that compounds the value of every other improvement on your list, and that addresses a pain point felt not just by developers but by every BIM coordinator, project manager, and contractor in the industry. I think it deserves to be the organizing principle of the roadmap rather than one item among many.
Why version control is the category nobody owns
Every other improvement on your list — web performance, TypeScript support, faster loading — is a catch-up game against Web-IFC and IFC Lite. These are important, but IfcOpenShell is playing defense. Version control is different. The proprietary platforms have crude, file-level versioning at best. No open source project has solved it at the semantic level. IfcOpenShell could define this category rather than compete in an existing one.
IfcGit is already remarkable — nothing else does what it does. But right now it's "git applied to SPF files" rather than "version control that understands IFC." That distinction matters enormously, and closing that gap is what turns a clever tool into an industry-defining one.
The core technical problem and how to address it
IfcGit's current fragility stems from SPF's use of sequential step IDs as entity identity. Two authors editing the same model independently produce colliding IDs, and Git has no way to resolve this semantically. The solution is already present in the spec — GlobalIds — but they aren't being used as the primary identity layer for diffing and merging.
I'd propose tackling this in three stages:
First, an SPF normalizer that runs on write — sorting entities deterministically by GlobalId, stripping and reassigning step IDs based on that order. This ensures two files with the same logical content produce the same text, dramatically reducing diff noise from ID reassignment. This is achievable relatively quickly and immediately improves the IfcGit experience.
Second, a custom Git diff driver that parses both versions into object graphs and diffs by GlobalId rather than step ID. Instead of seeing raw SPF line changes, you see: "Wall X had its height changed from 3000mm to 3500mm." Human-readable, semantically meaningful, and buildable as a Git extension today without touching Git itself.
Third — and this is the hard part — a custom merge driver. A three-way IFC merge would identify the common ancestor, track changes in each branch by GlobalId, auto-merge non-conflicting changes, and flag true semantic conflicts where the same property was changed differently in both branches. The key insight is that most real BIM conflicts are actually auto-resolvable if you understand IFC structure. Two architects editing different rooms rarely touch the same entities.
How this unifies the rest of the roadmap
This is where I think the version control thread becomes genuinely powerful — it doesn't compete with the other items on your list, it gives them coherence:
Instant IFC loading becomes an obvious prerequisite. You can't run diff and merge operations in CI pipelines with 20-second load times. Fixing loading speed stops being "a performance issue" and becomes "the thing that makes version control workflows viable at scale."
Federation becomes more tractable. If you can diff and merge between models, cross-referencing them is a smaller conceptual step. The version control layer provides the identity and change-tracking infrastructure that federation needs.
AI and MCP integration becomes genuinely compelling. Agents can propose changes as branches, reviewers can inspect semantic diffs, conflicts can be surfaced for human resolution. This is a much stronger story than "AI can query your model" — it's "AI participates in your design workflow with full auditability."
Hybrid serialisation can evolve without breaking things. If SPF is normalised on write and the semantic layer is the source of truth, you can experiment with RocksDB or other formats for runtime performance without corrupting git history. The two concerns are cleanly separated.
The pitch beyond developers
Your curl/ffmpeg framing is compelling to developers. The version control story is compelling to everyone else. Every AEC professional immediately understands the value of:
Branches. Merges. Pull requests. Audit trails. Rollbacks. But for your building model, and with full understanding of what actually changed.
This pulls IfcOpenShell out of the "developer library" category into something with direct organizational relevance — something a BIM manager can explain to a client, something a contractor can point to when a dispute arises over who changed what and when.
What I'd propose concretely
Rather than the current roadmap as a parallel set of workstreams, I'd suggest framing development around a single north star: making IfcOpenShell the foundation for a genuinely semantic BIM version control workflow. The immediate priorities become:
Everything else on your list either falls naturally out of this workstream or can be driven by contributors with specific needs rather than requiring core team focus.
I recognise this is a significant reframing and there's a lot of detail to work through. But I think IfcOpenShell is sitting on something genuinely significant with IfcGit, and the risk is that it stays a footnote while the team spreads energy across too many fronts. The version control story is the one that nobody else is telling — and that nobody else can tell, because nobody else has the foundation you've built.
Would be very interested in your thoughts, and happy to dig into any of the technical specifics.
A follow-up
One more thought to add to the above, and I think it strengthens the case further.
AEC doesn't just lag — it lags in a predictable pattern
The construction industry has a well-documented history of adopting technology a decade or two after every other industry, and typically adopting the version that the rest of the world is already moving away from. We got CAD after manufacturing. We got databases after finance. We got cloud collaboration after software development. And critically — we always arrive just in time to adopt the previous generation's solution.
Version control is following exactly this pattern. Right now the AEC industry is excitedly solving its equivalent of the Centralised Version Control problem — the SVN era. BIM360, ACC, Revit Server, Trimble Connect — these are all variations on the same model: a central server holds the truth, users check out, edit, and commit back. One canonical copy. Locking. Central authority. It's Subversion, dressed up in construction industry clothing, arriving about 15 years late.
The rest of the software world abandoned this model for a reason. Centralised version control breaks down when teams are distributed, when you need to work offline, when you want to experiment without affecting the main model, when contributors are external, when you need to audit not just what changed but why and by whom across parallel workstreams. These aren't edge cases in AEC — they're the norm. Projects span continents, consultants work offline on site, design options branch in a dozen directions simultaneously, contractors need read access without write authority.
Git didn't just improve on SVN. It changed the underlying model entirely — from "one truth, centrally held" to "eventually consistent, distributed truth." Every contributor holds a full copy. Branches are cheap. Merging is first-class. The network is optional. Collaboration is asynchronous by default. This is what made open source at scale possible. This is what made modern software development possible.
AEC needs to leapfrog, not catch up
The opportunity in front of IfcOpenShell is not to build a better BIM360. It's to skip the centralised era entirely and solve the distributed, eventually-consistent workflow that the industry will inevitably need — before the industry knows it needs it.
That means:
This is not a fantasy. It's exactly what Git gave software development, and the AEC industry's data — IFC, with GlobalIds, with a rich semantic schema — is actually better suited to this model than raw source code ever was. Code has no native concept of identity across versions. IFC does. We have a structural advantage that we're not exploiting.
The window is narrow
The centralised platforms are well-funded, deeply embedded, and moving fast. If IfcOpenShell spends the next three years closing the performance gap with Web-IFC while BIM360 and its competitors mature their centralised workflows, the industry will standardise on the SVN model and the opportunity to leapfrog closes.
But if IfcOpenShell ships a genuinely distributed, semantically-aware version control workflow first — even as a rough but working prototype — it establishes the paradigm. Standards bodies, enterprise tools, and eventually the proprietary platforms follow paradigms set by working open source implementations. Git didn't kill SVN through marketing. It killed it by showing a better model in practice.
IfcOpenShell has everything it needs to do the same thing to the AEC industry's collaboration problem. The question is whether that's the bet we want to make.
@theoryshaw you should feed your bot with the source for ifcmerge, and see what it says - because ifcmerge is a solution to the impracticality of using GUIDs for version control.
Basically, only some IFC entities have GUIDs, walls do but materials and most other entities don't, so the question "are these two IFC structures equivalent?" is almost impossible to answer. In an Open BIM situation you don't really care because IFC data is only shared as a read-only reference view.
For this response, I used Cluade Code on top of the IfcMerge repo, and fed it our threads up to now.
brunopostle — fair correction, and having now read the ifcmerge source, the GUID framing in the earlier posts was too simplistic. Let me try to steelman what ifcmerge is actually doing, because I think it's more elegant than the GUID approach I was describing, and it strengthens the broader argument rather than undermining it.
The GUID approach has the problem you identified
You're right that GUIDs only exist on "rooted" entities — walls, spaces, objects, relationships. The majority of the IFC graph is anonymous: geometric representations, material definitions, local placements, property sets, geometric contexts. These entities have no stable identity across independent edits, so asking "are these two structures equivalent?" requires graph traversal and heuristic matching that would be slow, brittle, and failure-prone. A GUID-based merge would either miss most of the graph or make expensive guesses about it.
What ifcmerge actually does — and why it's better
ifcmerge sidesteps the identity problem entirely by using a different anchor: the SPF numeric ID, under the Native IFC protocol. The protocol's key constraint is ID preservation — entities keep their numeric IDs across saves. Unchanged entities are written back verbatim. Deleted IDs are never reassigned. New entities are appended at the end.
This turns the identity problem from "match semantically equivalent structures across independent graphs" into "track numeric ID changes across three versions of the same file." That's a fundamentally simpler problem, and the merge algorithm reflects it — roughly 400 lines of clean three-way logic: additions don't conflict, single-branch modifications are accepted automatically, dual modifications attempt attribute-level merging by position, and dependency integrity is checked at the end.
The renumbering strategy is particularly clever: when both branches add entities (and thus generate colliding IDs), local entities are offset upward so remote IDs are never touched. Simple, deterministic, no heuristics.
The Open BIM constraint is real and important
Your point about Open BIM is one the earlier argument glossed over. ifcmerge/Native IFC only works within a single authoring context where the ID preservation protocol is respected end-to-end. The moment a file crosses a tool boundary — exported from Revit, imported into another application, re-exported — ID stability is lost and the merge approach breaks down. In Open BIM, where IFC is a read-only exchange format, you can't assume this.
This is actually a meaningful limitation on the distributed version control argument: the "branch, merge, pull request" workflow requires participants to author natively in IFC, not export to it. That's a workflow constraint that most of the industry isn't ready to adopt yet. But it's the right direction to push, and the Native IFC movement is precisely the prerequisite for making this work at scale.
The broader argument still holds — it just needs sharper framing
The case for IfcOpenShell as the foundation for distributed BIM version control isn't "use GUIDs like git uses content hashes." It's "the Native IFC protocol creates the conditions under which a real merge tool becomes possible — and ifcmerge proves it works in practice." The GUID approach would have been a dead end; the ID preservation approach is already running.
What's still missing is the semantic diff layer on top — something that translates SPF-level changes into human-readable descriptions of what actually changed in the model. That's where GlobalIds become useful: not as merge identity anchors, but as a lookup layer for surfacing "wall A3-101 height changed from 3000mm to 3500mm" rather than "#3518 attribute 4 changed." The merge logic stays ID-based; the reporting layer uses GUIDs where they exist and falls back to type/position context where they don't.
Would be interested in your view on how far the Native IFC protocol has actually penetrated authoring workflows in practice — that seems like the real constraint on how widely this can be deployed.
It sort-of proves that you can get the bot to say anything you like.
Though it had an original idea that has legs that I hadn't considered: "something that translates SPF-level changes into human-readable descriptions of what actually changed in the model". We can totally do this with git diff, ifcmcp and ifcquery; I bet we can simply ask ifcmcp to describe the changes between any two revisions: "What did Ryan do on Monday, and how is it different to what he said he did?".
Asked mr bot to parse out this idea more
The semantic diff layer is worth unpacking in full because it's actually a well-defined engineering problem with a clear implementation path, especially given what IfcOpenShell already provides.
What the raw SPF diff looks like
When ifcmerge processes a change, the output is at the entity level. A height change might look like:
Attribute 4 changed from
3000.to3500.. This is precise and correct, but completely unreadable without schema knowledge and graph traversal. No BIM coordinator can action that.The two-direction traversal problem
To make that change human-readable you need to go in two directions simultaneously:
Upward — walk the reference graph from
#3518toward the nearest entity that has a GUID. The chain is roughly:That gives you the subject: "Wall 'A3-101'"
Downward — use schema knowledge to name what changed. IfcExtrudedAreaSolid's attribute positions are fixed by the schema: attribute 4 is
Depth, typed asIfcPositiveLengthMeasure. That gives you the predicate and values: "extrusion depth changed from 3000mm to 3500mm"Combined output: "Wall 'A3-101': extrusion depth changed from 3000mm to 3500mm"
Why IfcOpenShell is uniquely positioned to do this
The two ingredients — upward graph traversal and downward schema introspection — are both things IfcOpenShell already does well. The schema is baked in. Inverse relationships are tracked. The upward walk is just following inverse references until you hit a GUID-bearing entity. No other library has this combination already working and battle-tested.
The fallback hierarchy when no GUID exists
Some entities have no GUID ancestor — global geometry contexts, shared material definitions, profile definitions. The fallback isn't silence; it degrades gracefully:
IfcMaterialhas aNameattribute. Use it: "Material 'Concrete C30': density changed"IfcGeometricRepresentationContexthas aContextTypeattribute: "Model geometry context: precision changed"The goal is that every change has at least a meaningful type-and-parent description, even if the full semantic chain can't be resolved.
GUIDs as cross-version anchors, not merge anchors
This is the distinction worth being precise about. In the merge operation, GUIDs are irrelevant — SPF IDs do the work. But in the diff report, GUIDs serve a different purpose: they let you link the same element across commits even after renumbering.
If a merge causes local entities to be renumbered (the offset mechanism),
#3518in commit A might be#3621in commit B. If you're reading a git log of changes to Wall 'A3-101' across 10 commits, you need GUID-based lookup to maintain continuity. The diff layer says "find the wall with this GUID, report what changed about it" — independent of what SPF ID it happens to have in each version.What this looks like end-to-end
The pipeline is:
Each step is independently useful and independently testable. The first step already exists (ifcmerge). The last three are pure IfcOpenShell operations. The middle step — GUID/name lookup — is the novel piece, and it's essentially a constrained graph traversal with a well-defined termination condition (stop at the first GUID-bearing ancestor).
The reason this matters beyond readability: once you have a semantic diff, you can do things like audit trails that non-developers can actually read, automated change notifications to relevant stakeholders ("you're the responsible engineer for this wall"), and PR review workflows where a BIM coordinator approves a merge the same way a senior developer approves a code change — by reading a diff that makes sense.
OMG is IFC Lite fast.
I threw a 459 MB IFC into the browser and expected that would make it crash. the opposite. it took about 2 seconds to open the model and everything works real time. I have never seen something like this before .....
This works, here is ifcmcp asked to give a day by day narrative of the changes in an IFC repository (ifcmcp is a bot that knows how to read and modify IFC models):
Design Log — My Building
A day-by-day account of how this IFC building model grew from a structural shell into a fully furnished two-storey community building with service extension and south garden.
24 February 2026
The building model began its life as a complete structural skeleton: four exterior walls forming a compact 4 m × 6 m rectangular plan on the first floor, sitting on four concrete ground beams and footings. Above the walls a pitched timber roof spans the space, with eaves corona and tile coverings wrapping the edges and gutters running along the lower eave. The single internal room was defined as
living-space/0, fitted with eight sash windows — tall arched lights on the north and south elevations, and wider sash-big openings on the east and west.With the geometry in place, the model was immediately put to work. Element quantities were computed for every wall, slab, footing, and roof panel, and a full construction schedule was written: Foundations → Structure → Roof → Openings → Finishes, with durations running from 2 days for the gutters up to 8 days for the walls. A Bill of Quantities cost schedule was also set up, ready to receive unit rates. The last task of the day was to add
FireRatingandThermal Transmitanceproperties to the wall common property set to satisfy a pending IDS validation requirement.The original building as it stood at the end of 24 February: a single room with eight windows and a pitched roof.
27 February 2026
Attention turned to the interior. Three elements transformed the bare room into a habitable space: a wood-burning stove was positioned as the hearth and focal point for communal gathering; a chimney was added rising through the roof; and a window seat was built into the south wall, inviting people to sit in the light. Outside the front door a bench was placed for people waiting or removing muddy boots, and an apple tree was planted nearby.
A library type for a Neufert Retail Dining Chair was also imported into the model at this point, anticipating future furnishing of the space.
Two housekeeping fixes were made: the work schedule's
PredefinedTypewas corrected fromBASELINEtoPLANNED(aBASELINEschedule without a parent to compare against causes the Gantt tool to crash), and a thermal transmittance property name that had been spelledThermalTransmittancewas corrected toThermal Transmitanceto match the IDS requirement exactly.End of 28 February: the entrance porch is in place, the panelled front door is installed and the chimney rises above the ridge.
28 February 2026
The main entrance was given proper architectural definition. One of the north wall windows — a wide sash opening — was removed and replaced with a panelled entrance door. This is modelled accurately: the original window and its opening element were deleted, a new door-height opening (2.08 m, no sill) was cut through the wall, and the door was placed and assigned its panelled door type.
Almost immediately a lean-to entrance porch was added on the east side of the building: three new walls (south, north and east faces) enclose a small lobby space that shelters the entrance from wind and rain. Two interior doors — a lobby entrance door and an interior lobby door — connect the porch to the main space. The lobby was formally defined as an
IfcSpace(entrance-lobby/0), and the construction schedule was extended with tasks for Erect Porch Walls (2 days) and Install Lobby Doors (1 day).The schedule also gained tasks for the stove, chimney, window seat, bench and tree added the previous day, each assigned their newly computed quantities.
1 March 2026
The busiest day in the project's history. Seven significant design moves were made, more than doubling the model's element count.
Lean-to porch roof. The porch walls were trimmed to a sloped lean-to profile — a half-space clipping replaces a simple extrusion so the walls taper correctly from 3.26 m at the building face down to a 2.38 m eave. A shallow pitched porch roof slab was added over the entrance, giving the cascade-and-sheltering quality of Pattern 116/117.
Fire-exit door. A second door was added to the south wall, providing a safe secondary exit from the main space.
South outdoor gathering space. A generous outdoor room was defined south of the building: a paved area with three low sitting walls (south, east and west edges) forming an informal enclosure. Four garden chairs were placed within it. This follows Patterns 105, 161, and 163 for outdoor gathering.
South service extension. A single-storey service wing was added to the south side of the main building — three perimeter walls plus an internal partition dividing the space into three rooms:
service-lobby/0— circulation between the main building and the service rooms-
wc/0— fitted with a toilet, basin, and two windows (west and south)-
kitchenette/0— fitted with a bench, sink, and two windows (east and south)A flat extension roof was placed over the extension and three internal doors connect the rooms. Sanitary and kitchen fixtures were imported from the Bonsai asset library (Neufert Toilet, Neufert Small Basin, Neufert Small Kitchen Bench, Generic Small Sink).
Landscape. The apple tree was moved from its original position beside the building to a new position further south, clearing the extension footprint. Eight small shrubs were planted around the building perimeter (two on each side).
Quantities and BoQ. All new elements were quantified and added to the construction schedule (tasks: Erect Extension Walls, Install Sanitary and Kitchenette Fixtures, Build Garden Sitting Walls and Paving) and the Bill of Quantities.
End of 1 March: the building has grown its service extension, the south garden is paved and planted, and the apple tree has moved to its new position.
5–6 March 2026
A dining table was built from scratch using the shape-builder API: four circular-section legs (30 mm radius, 720 mm tall) and a rectangular tabletop (1 400 × 800 mm, 40 mm thick). The table was placed in the living space and assigned a furniture type.
The first version used an
IfcBlockprimitive for the tabletop, which caused a schema validation error (CSG and SweptSolid items cannot share the sameIfcShapeRepresentation). The next day the tabletop was rebuilt as an extruded rectangular profile, keeping all items asSweptSolidand resolving the validation failure.9 March 2026
Six Neufert Retail Dining Chairs were placed around the table — two on each long side, one at each short end — completing the dining group. All six chairs were initially placed facing the same direction (the library default). They were then corrected so that each chair faces inward toward the table: the two south chairs rotated 180°, the east chair rotated 180° about Z, and so on, depending on which side of the table they sit on.
End of 9 March: the dining group is complete — table, six inward-facing chairs, stove and window seat — seen through translucent walls.
11–12 March 2026
A series of geometry corrections improved the quality of wall junctions throughout the model.
Wall mitre connections. The corners where the porch walls and the extension walls meet were upgraded from simple abutting ends to properly mitered connections. Each wall pair was given an Axis/Curve2D representation and connected via
IfcRelConnectsPathElements;regenerate_wall_representationwas then called to recompute the mitered profiles. For the porch walls (which also carry a slope clipping), the mitre was baked directly into the 2D profile as a trapezoid rather than using two half-space clippings, which would have produced viewer artefacts.Porch geometry. The porch wall slope clipping normals were corrected (the normal must point toward the removed material, i.e. upward, which is counter-intuitive), and the west extension wall geometry was fixed to match the new mitered profile.
Opening alignment. Window and door openings in the service extension were repositioned to align correctly with their host walls.
Dining table resize. The table dimensions were adjusted.
Quantities, costs and the construction schedule were recalculated to reflect the updated geometry.
19 March 2026
The building gained a second storey. Until now all four exterior walls had been on storey
1(the first and only occupied floor). The model was restructured so that:2(the upper floor), keeping all their geometry intact.ground-south,ground-north,ground-west,ground-east) were created on a new storey1, with the same rectangular footprint.first-floor-slab) was added at the 3 m level to separate the two floors.The construction schedule was extended with a Ground Floor phase covering Ground Floor Walls (15 days), Ground Floor Slab (5 days) and Ground Floor Windows and Door (5 days).
End of 19 March: the building is now two storeys. The new ground-floor walls and first-floor slab are visible below the original upper-storey windows and roof.
20 March 2026
The ground floor window set was completed. Additional openings were added to bring all elevations to their final fenestration:
win-north-2)win-west-3)win-east-1,win-east-2)This brings the ground floor to nine windows plus the entrance door.
The construction schedule underwent a significant correction. All element-to-task assignments were changed from
IfcRelAssignsToProcess(which marks an element as an input to a task — material being consumed or demolished) toIfcRelAssignsToProduct(which marks an element as an output — the thing being constructed). Using the wrong relationship type caused the Bonsai construction animator to crash with aKeyErrorwhen trying to animate CONSTRUCTION-type tasks. The sequence ordering was also corrected so that ground-floor walls are built before first-floor walls, which had been reversed.Final state
The model as it stands describes a two-storey community building: a generous double-height living room on the ground floor opens through a porch lobby to the east; the first floor above holds the main social space with its eight sash windows, dining table and six chairs, window seat and wood-burning stove; a single-storey service extension to the south provides WC and kitchenette facilities; and a paved south garden with sitting walls, garden chairs and shrubs completes the outdoor setting. A large apple tree stands to the south-west.
The completed model as of 20 March: two storeys, lean-to porch, service extension, south garden and full window complement.
To be clear: not just this summary but all the changes in this model were by an ifcmcp bot responding to issues in a bug tracker.
This all sounds great to be honest!
Yes first class library for web ifc authoring is maybe most needed feature in IFC world so can be easily generating ifc views in web browser but also generating ifc or editing simple futures
OK, a month and a bit later, we now have significant progress on quite a few of these initiatives. Unfortunately, none of this is yet available via the build system so the only way to try it out is to compile the code yourself. However, I truly hope in the next few weeks we will have a build up of at least one of these. Let's go!
There are 2 updates here. Firstly, Sayan's GSoC project which will start soon and make this a reality. Second, starting around this commit (with full details in PR) @aothms has been decoupling the C++ side of things so that instead of IfcOpenShell being one monolithic software, it now treats serialisers, geometry kernels, and schemas as plugins (shared libraries - a.k.a. dlls). So basically "IFC4" is a plugin, "OpenCascade" is a plugin, "GLTF" is a plugin, and so on. This breakdown is a huge deal in code portability and reuse.
A huge amount of profiling was done comparing IfcOpenShell to web-ifc and IfcLite. We measured where we were fast and slow, and this lead to the introduction of the Manifold geometry kernel. Note that IfcOpenShell is unique in that it supports hybrid kernels, each kernel has pros and cons, so in IfcOpenShell you can mix and match. Manifold is fast, but it is not technically correct (i.e. in implementation of IFC's precision attribute), but this is a tradeoff you can make for simple shapes, for example.
This, along with other improvements means that IfcOpenShell is much faster now.
The big win in improvements in geometry (with multicore). On the IfcLite profiling test case model set, IfcOpenShell is faster for geometry on ~half the models (13/26), web-ifc on 9, with 4 roughly tied. Basically, if you want speed for geometry, IfcOpenShell is now much better than before (edit: removed previous incorrect claim). However, web-ifc has a 3-7x parsing advantage (i.e. to "open" the file) means it still wins in terms of total time (from open, to geometry, to close) on 22/26 models. Parsing, not geometry, is now IfcOpenShell's main bottleneck when multiprocessing is available. More work still to be done. In particular this addresses the "Instant IFC SPF loading for non-geometric queries" concern. Also note XBim was not assessed. Edit: also note the ifclite tests were not comprehensive (e.g. Ifclite actually does support multithreading)
This also kicks off a body of work around geometric correctness. Just because you are fast, does not mean you are correct. Initial experiments have started (for internal correctness between kernels) so watch this space. See full profiling analysis here.
After discussion, it is likely the HDF5 support will be dropped. RDB will likely take a prominent position as a replacement for IFC-SPF in many workflows (at work, I hope to roll it out sooner than later once some bugs are fixed). There has also been work on a highly compressed geometry-only cache currently just nominally called "IFCVIEW". I have written a page of docs explaining what all these things are but have not yet committed. Next time.
This chart shows filesize comparisons tested across real life projects. IFC is the
.ifcSPF format..ifcformat you know. Plaintext.Note that these are generalisations. There are always tradeoffs with any technology, and you can see some examples here where plain old .ifc text is even smaller than "optimised binary blah blah".
A desktop viewer
This is the big one for users. Work is done here. In short, there is no free software equivalent of Revizto, BIMCollab, Solibri, etc. We are building one, and whilst doing so, enabling others to also build their own desktop (tablet? kiosk? on-site screens?) apps. Here's the current state of the UI:
It's designed to be simple to use (i.e. most complex stuff hidden away, no 1000 buttons like Blender) and super speedy. Speedy as in, in my current tests, I have loaded 111 real-life large project models (from work) in under 10 seconds, which have over 1,000,000 objects, where I can navigate and fly around like superman with 60FPS using only 4GB of RAM. Note this is precomputed caches, similar strategy to XKT / Fragments. The intent is that you can cloud-generate these caches and then cloud sync (4GB RAM ~= 4GB full network download for 111 models) so that teams can quickly load up models.
This geometry cache (currently named "IFCVIEW" as a placeholder) can be coupled with IFC RDB. This means instant IFC open times with negligible memory usage. The RDB can be lossless, or lossy (for read-only). For lossy, we can choose what classes to omit, so if we exclude geometry (so RDB for data, IFCVIEW for geom) we get in my example ultra-high-load scenario 5GBs (4GB geom + 1GB data) for 111 models. The original SPF was about 10GB (note these are quite curated IFCs, not full of arbitrary bloat, some of which are incredibly dense steel where even plaintext geometry is smaller than binary triangles).
Georeferencing support has recently been implemented in it, which I think is one of the big things which set us apart from other viewers - that we have correct coordinate handling. That in itself took half my weekly Claude tokens to do ;)
Awesome work @Moult , I can't wait to get my hands on this thing and use it as my main IFC non-authoring tool!
@Moult Is maybe planned rules set manager for checking models by the rules with combined with IDS , and online respiratory for sharing rules sets like
https://help.solibri.com/hc/en-us/articles/1500004624081-Using-the-Ruleset-Manager
Also maybe MCP like interface if is possible for modern ifc checking
And is possible to add git version and issues control so this can be viewer and bonsaiBIM or free cad as authoring platforms but work simultaneously on one project , multi viewers multiple bonsaiBIM and version control
I had interpreted IFC as an entity-relationship data model, so I assumed it used RocksDB’s key-value NoSQL database, but are you saying it turned out to be an RDB? Amazing
Does the viewer render out Bonsai drawings? That would be cool.
I can't wait to see what comes next, it looks amazing already!
A suggestion for the user interface: it would be great to have a “command finder” so we don't have to rely so much on “finding the right button,” even though the panels look nice and clean in the preview.
The best examples I know of this kind of tool are the bimdots tool for Archicad and the AutoCAD's command line (yes, I know... but it still works great to this day).
I have a feeling that button-based UI will soon become outdated, as we’re all moving towards natural language input. It’s worth thinking about it, so please consider if possible.
Not for me.
I am a notorious button clicker. Muscle memory.
@zoomer
I'm all for keystrokes, direct like in Blender or QCAD, no command line stuff
Never used the gizmo :)
Hello, thought I'd chime in 😉
First: really appreciate this race. Wonderful that we can run it on open, free libraries. That's exactly why I started IFClite a few months ago. Not one library to rule them all, but a diverse, openly accessible landscape covering the full range of IFC use cases. OK, stage set 😅
I kindly disagree, but I think the disagreement is mostly about which IFClite path is being tested.
I forked the profiling harness, kept the framework intact (Parse / Geometry / Total, same exclude set, same 21 public files) and added the missing series: IFClite's native Rust deployment alongside the WASM one. Same chart layout, more bars, plus a geometric-output panel and a proposed zero-copy category at the bottom.
from Apple M4 / 10c / 16 GB / Node 22:
Fork with code, chart, RESULTS.md, raw JSONs, and per-file product/triangle validation:
github.com/louistrue/profiling/tree/apples-to-apples-with-native
A few places where the original chart underweights IFClite, from where I sit:
1. The native Rust server ships at
@ifc-lite/server-binwith rayon multi-threading and is the production deployment. Adding it flips most per-file rankings.2. The Total column sums two independent IFClite parsers. TS-side parseLite (non-geom queries) and WASM-side parseMeshes (geometry) are alternative entry points, not pipeline stages: parseMeshes does its own internal parse from scratch. My fork reports them as separate races and uses a single-call native pipeline for the native rows.
3. Zero-copy as a proposed fourth category. parseZeroCopy returns a single concatenated, GPU-upload-ready buffer with WASM-memory views. Different output shape than iterator(), so not strictly apples-to-apples, but it's what real viewers consume. Panel 4 measures it against a web-ifc reference (what a viewer would otherwise assemble manually: OpenModel + StreamAllMeshes + GetGeometry/Vertex/Index + JS concat). IFClite wins 21/21, median 2.4×.
One more thing: real-world models are reaching 1GB+ now, and that's where IFClite's columnar / lazy / zero-copy architecture was designed to shine, both for raw speed and memory footprint. I'd expect the gaps to widen once larger models are added to the corpus.
To be clear: this isn't a "IFClite beat IOS" post. IfcOpenShell remains the correctness reference, the schema authority, and frankly the only engine handling the full depth of IFC-the-spec properly. The numbers should read as: for the narrow-but-common workload of parse + per-element mesh, native Rust IFClite runs faster than what's been measured so far. More options for the ecosystem, and the correctness conversation keeps going ✌️
Happy to be challenged on any of this. Fork is open, harness is reproducible, every finding documented in RESULTS.md.
Let's keep rocking 🚀
Louis
*edited chart at 10:29 CEST, wrong IOS numbers (from my machine, not Dions...)
I forked the profiling harness, kept the framework intact (Parse / Geometry / Total, same exclude set, same 21 public files) and added the missing series: IFClite's native Rust deployment alongside the WASM one. Same chart layout, more bars, plus a geometric-output panel and a proposed zero-copy category at the bottom:
1. The native Rust server ships at @ifc-lite/server-bin with rayon multi-threading and is the production deployment. Adding it flips most per-file rankings.
Louis
Thanks @louistrue ! I had no idea when I was running the tests that IfcLite had these different settings and multi-threading. Also perhaps worth mentioning that the tests I ran for IOS were not using hybrid-cgal-simple-opencascade, but instead the new hybrid manifold kernel along with the new changes in the datamodel branch.
For those following along, @louistrue and I had a chat recently to discuss these results and if we could share a benchmark suite, so we could measure correctness and speed across many kernels, technologies / settings, and environments. I'm really looking forward to collaborating more on this suite. https://github.com/IfcOpenShell/benchmark is the (currently blank) repo for anyone who wants to peek in when the first commit lands. The idea is that we can start by assuming IOS's opencascade is the slow but likely correct result, then compare against that (and if it turns out opencascade isn't correct, we can choose a new correct result).
Watch this space :) Hopefully more news in the next update.
I’m looking forward to IfcOpenShell/benchmark 🤩
I’m keen to see if it’s faster when compared to OCCT_VERSION=7.8.1 in IOS 0.8.5 and the recently released OCCT_VERSION=8.0.0
I like where this is going!
Will only the Bonsai Viewer profit from this ?
Or also Bonsai, or would it then be bottlenecked by the connection to its host, Blender ?
@zoomer everything will benefit from this - the Bonsai Viewer, Bonsai in Blender (but only in some scenarios, since in most scenarios Blender is the bottleneck), the upcoming IfcOpenShell for the web, all IfcOpenShell based scripts that work with geometry (at work, I have a lot and I know a lot of other companies too) as well as all utilities (e.g. IfcClash, IfcConvert, ...).
Thanks @Moult
that sounds fantastic.
Honestly, so far, I never felt that Blender itself is bottlenecked in any way (?)
(Viewport, switching Visibilities, Outliner, loading/importing files, accessing/changing Properties, Selections, Snapping)
Even when loading my largest most ugly geometry examples and compare to my other Apps.
Are there special known issues where it is worth to avoid or keep an eye on ?
I remember that manual spatial sorting IFC in Outliner was given up for such (?) reasons but I never experienced any so far.
OK, I read about the bottleneck in one of the Links in https://community.osarch.org/discussion/comment/28921#Comment_28921
To me that sounds very reasonable and very exciting !
When reading through things that are far ahead of me and I don't understand (https://github.com/elalish/manifold), I have to think my concerns about geometry/accuracy degradation to dumb Meshes (also valid for Yorik's LinesCAD project thread) isn't real (?)
So no loss like Pixel vs Vector, Mesh vs mathematical Solids (?)
So .....
if Bonsai Viewer has its own autark geometric and graphics engine, its own modeling tools, .....
there is no more much dependent/needed from Blender host left (?)
May Bonsai authoring one day develop to a standalone App ?
Just a small update because a lot is happening but it takes time to type it all up. Please check out https://builds.ifcopenshell.org/ for builds called BonsaiViewer that you can test with! Current status:
Coming soon: MacOS, web, actual data being shown (right now the properties / spatial tree is just a dummy mockup), even more speedups, streaming, known stability and geometry correctness, ...
I notice the Linux builds are from quite a few days ago, with a lot of Windows only builds since then. Are they still up-to-date?
