[Bonsai BIM 0.8.4] Wall corner not aligning correctly — how to fix it like a clean corner join?
Hi everyone,
I'm working on a simple house model in Bonsai BIM and I have a wall corner alignment problem.
In image 1 you can see how the corner looks when it's correct — the walls meet cleanly.
In image 2 you can see my problem — walls no is not aligning properly at the corner, doesn't join cleanly like in image 1.
I tried adjusting the corner with Shift+E but couldn't get it to align correctly like in image 1.
What is the correct workflow in Bonsai BIM to get a clean wall corner join like in image 1?
Thank you!
  • Did you try the Trim tool (Shift + T)?
    steverugiDarius_Hisem
  • @semhustej Thank you! Could you explain the exact steps for using the Trim tool? Which wall do I select first, and what exactly should I do after pressing Shift+T? Nothing happens when I try it.
  • @semhustej Never mind, I managed to fix it! The issue was a error in the wall itself, which was preventing the Trim tool from working. Once I fixed that, Shift+T worked perfectly. Thank you!
    semhustej
