How to create an IfcElementAssemblyType from a set of IfcElementTypes?
I remember that at one point in the past I was able to create an assembly of objects types (I did it once but I don't remember which version of BB) but now I can't.
I tried this:
Method 1 - Create the assembly type and assign the aggregated type objects
The assembly type object is not shown for selection.
Method 2 - Create the assembly type from an existing object type
Generates an error:
os: Linux
os_version: #107-Ubuntu SMP PREEMPT_DYNAMIC Fri Mar 13 19:51:50 UTC 2026
python_version: 3.11.13
architecture: ('64bit', 'ELF')
machine: x86_64
processor: x86_64
blender_version: 5.0.0
bonsai_version: 0.8.5-alpha260410
bonsai_commit_hash: a3efa7e
bonsai_commit_date: 2026-04-10T19:11:42+05:00
bonsai_git_branch: v0.8.0
last_actions:
# operator: BIM_OT_save_project
# operator: BIM_OT_add_aggregate
# operator: BIM_OT_assign_class
# ifcopenshell.api: root.create_entity
>>> {"ifc_class": "IfcElementAssemblyType", "predefined_type": "", "name": "Default_Name"}
# ifcopenshell.api: owner.create_owner_history
# ifcopenshell.api: geometry.edit_object_placement
>>> {"product": {"cast_type": "entity_instance", "value": 334, "Name": "Default_Name"}, "matrix": {"cast_type": "ndarray", "value": [[1.0, 0.0, 0.0, 0.0], [0.0, 1.0, 0.0, 0.0], [0.0, 0.0, 1.0, 0.0], [0.0, 0.0, 0.0, 1.0]]}}
last_error: Traceback (most recent call last):
  File "/home/wal/.config/blender/5.0/extensions/.local/lib/python3.11/site-packages/bonsai/bim/ifc.py", line 523, in execute_ifc_operator
    result = getattr(operator, "_execute")(context)
  File "/home/wal/.config/blender/5.0/extensions/.local/lib/python3.11/site-packages/bonsai/bim/module/aggregate/operator.py", line 227, in _execute
    core.assign_object(tool.Ifc, tool.Aggregate, tool.Collector, relating_obj=aggregate, related_obj=obj)
  File "/home/wal/.config/blender/5.0/extensions/.local/lib/python3.11/site-packages/bonsai/core/aggregate.py", line 46, in assign_object
    raise IncompatibleAggregateError
bonsai.core.aggregate.IncompatibleAggregateError
blend_file_path: Not saved
blend_file_dirty: N/A
ifc_file_path: /home/wal/Estudos Blender/Sinalização_viária/Prototipo_aplicao/1-assembly.ifc
ifc_is_dirty: True
ifc: 1-assembly.ifc
schema: IFC4X3
preprocessor_version: IfcOpenShell 0.8.5-alpha260410
originating_system: Bonsai 0.8.5-alpha260410-a3efa7e
Does anyone know if it's possible to do this, and can help me?
Thanks
