BONSAI / Door / Qto_DoorBaseQuantities / width not correctly calculated
edited April 15 in General
Hello community,
I’ve been working with BBim doors and noticed something odd regarding how the door width is calculated.
Is there a known issue or bug related to door width? From my observations, when the width is greater than the height, the calculation of door width seems to display more correctly in Qto_DoorBaseQuantities. Otherwise when width is smaller then height the width is calculated as the height.
I’ve attached some screenshots to illustrate the behavior.
Has anyone encountered this before or can clarify whether this behavior is a bug?
Thanks in advance for any insights!
L
if the width is greater then height it looks better.
