FreeCAD is a parametric CAD software, so it enables parametric setup of elements. This tutorial shows how to setup BIM objects such as walls or columns to adjust to level height automatically:
Based on the discussion in this forum thread, I recorded a video showcasing the differences between copying BIM objects using five different techniques. Each of them has its advantages and disadvantages:
Structural Project Course for FreeCAD BIM has been released in full. You will learn how to create a small building structural project including the 3D model and sheets with floor plans and sections. The course is divided to 9 lessons:
Introduction
Setup of FreeCAD for BIM work
Setup of project – grid, levels, units
Creation of the 3D structural model of the building
Level 01 floor plan drawing creation
Creation of sheet with title block and placing level 01 floor plan drawing on it
Creation of sheet with Level 02 floor plan drawing
:D Try Link first, if it doesn't work / work well (at the moment), fallback to Draft Clone.
But via your link I finally came to Freecad's Help/Wiki.
Which is astonishing comprehensive. I like it.
This video shows how to use BIM_DrawingView, which is a new tool in FreeCAD 1.1. It streamlines the creation of floor plans and elevations.
That's exactly what I am currently trying to do ..... cool ....
You can watch the whole course here:
This quick tip explains the preset behavior of the Window and the Door tool in FreeCAD BIM, which might easily confuse new users.
