Affect different status to two representations of the same object in IFC
Hello,
In IFC, would it be consistent (and possible in Bonsai?) to assign two different EPset_Status ( DEMOLISH, NEW) values to two representations of the same object?
In other words, how would you approach modeling an object whose geometry has been modified? For example, in HBIM, for a stone block that has been damaged, I want to have both the current geometry as it was surveyed and the geometry it had at the time of construction.
Thanks!
@RaphaëlVouilloz
I suspect you need two separate elements for that with their respective status, they can be turned on/off accordingly using a dedicated panel:
BTW if you wonder why the
Statuspanel is underCosting and Schedulingyou are not alone ;)Thanks @steverugi !
I didn't' know about this menu, I was using the general properties panel
