Open CAD Studio (with native DWG/DXF support)
Open CAD Studio: a modern, Open Source 2D + 3D CAD application that reads and writes DWG and DXF natively built in Rust, with GPU-accelerated rendering.
Starts < 1 second. Size 30 MB
No license. No converters. No workarounds. Just open, draw, save.
What's in it:
➡️ Full 2D drafting — LINE, PLINE, CIRCLE, ARC, ELLIPSE, SPLINE, HATCH, OFFSET, TRIM, EXTEND, FILLET, MIRROR, ARRAY, ROTATE, SCALE, EXPLODE… the entire AutoCAD-style command set
➡️ Native DWG & DXF (R13–R2018) read/write — the de-facto industry-standard format, without third-party library licenses
➡️ 3D modelling with ACIS solids tessellation — BOX, SPHERE, CYLINDER, EXTRUDE, REVOLVE, LOFT, SWEEP, ARRAY3D — and 3DSOLID/REGION/BODY entities from DWG render correctly
➡️ Paper space + layouts — multi-tab model space, viewport projection with inline MSPACE overlay, VPORTS presets, plot styles (CTB/STB), PRINT directly to system printer
➡️ Full dimensioning — linear, aligned, angular, radial, diameter, ordinate + DIMSTYLE with everything (DIMASZ, DIMSCALE, DIMEXO, DIMEXE…)
MLEADER, MTEXT, tables, GD&T tolerances, MLINE — with dedicated style managers
➡️ STL, STEP AP203, OBJ import/export, PDF plot, WBLOCK, XREF — everything you need to fit into an existing CAD chain
GPU-accelerated via wgpu — scales smoothly to large models with many solids
➡️ Under the hood: Rust for memory safety and performance, iced for the UI, wgpu for the GPU rendering. Cross-platform: Windows, macOS, Linux. GPL-3.0 license.
➡️ Product page: https://www.open-aec.com/open-cad-studio/
➡️ Repo: https://github.com/HakanSeven12/OpenCADStudio
➡️ Releases: https://github.com/HakanSeven12/OpenCADStudio/releases
Unfortunately it crashes while starting on Mac.
(See here : https://github.com/HakanSeven12/OpenCADStudio/issues/53 )
Will try again to install on Linux (ElementaryOS) these days ....
Im using Linux(Pop OS) and there is testers on windows side. But I dont have any Mac tester. So if you want to help I can try to fix issues for Mac.
I can try.
(I am just a software end user)
First can you create a seperate issue for the crush? So we can track the progress on that.
Done.
Can you test 0.4.8?
This is really, really awesome! I guess this is the question everybody is wondering ...
How is DWG support handled? An internal library? Any thoughts on other initiatives like LibreDWG?
Thanks! That's definitely the long-term vision, although we're not there yet. Regarding DWG support, Open CAD Studio is currently built on top of Acadrust, which itself builds upon AcadSharp. I'm building on existing open-source foundations and contributing improvements where I encounter missing functionality or compatibility gaps.
In practice, OCS development and Acadrust development often go hand in hand. When I need features, bug fixes, or support for additional DWG entities that aren't yet available, I try to contribute those improvements upstream rather than maintaining a completely separate implementation.
Compared to QCAD and LibreCAD, my focus is slightly different. Those projects are mature and have historically been centered around DXF workflows, where OCS aims to provide a modern CAD experience with DWG interoperability as a first-class concern. The dream is reaching a point where users can work with DWG files confidently without needing AutoCAD installed at all.
