arising problems when updating/installing Bonsai on Mac
Since a few weeks it began that updated Bonsai daily builds did not load in Blender 5.1.
While not having problems with 5.2 or 5.3.
Then I got the same 5.1 problem in 5.3 too, while 5.2 still ok. So for 5.3 I switched to BonsaiPR which worked.
Sometimes it loaded anyway after restarting Blender, sometimes not.
Anyway, meanwhile I reached a state where neither Bonsai daily nor PR will load on any Blender version :(
Could it be a problem that I have installed always both Bonsai versions, daily + PR ?
I do switch between these very seldom, but if, likely without restarting Blender, by deactivating the active, a bit of waiting and then activating the other version.
Do others experience similar problems installing Bonsai on Mac in general. Or switching between daily and PR in general ?
Usually I get a red error message (similar to restart hint after updating). Something like 2could not start/load Bonsai/more in Blender console)
In this case there are no usual entries in Blenders Scripting Tab.
And I do not find how to open Blender's console ....
OK, I got the message via Clipboard :
os: Darwin
os_version: Darwin Kernel Version 25.5.0: Mon Apr 27 20:41:15 PDT 2026; root:xnu-12377.121.6~2/RELEASE_ARM64_T6041
python_version: 3.13.13
architecture: ('64bit', 'Mach-O')
machine: arm64
processor: arm
blender_version: 5.3.0 Alpha
bonsai_version: 0.8.6-alpha260611
bonsai_commit_hash: 0c993d3
bonsai_commit_date: 2026-06-11T09:28:27+02:00
bonsai_git_branch: v0.8.0
last_actions:
last_error: Traceback (most recent call last):
File "/Users/user/Library/Application Support/Blender/5.3/extensions/raw_githubusercontent_com/bonsai/init.py", line 278, in
import ifcopenshell.api
File "/Users/user/Library/Application Support/Blender/5.3/extensions/.local/lib/python3.13/site-packages/ifcopenshell/init.py", line 98, in
from .ifcopenshell_wrapper import get_log, logger
ImportError: cannot import name 'logger' from 'ifcopenshell.ifcopenshell_wrapper' (/Users/user/Library/Application Support/Blender/5.3/extensions/.local/lib/python3.13/site-packages/ifcopenshell/ifcopenshell_wrapper.py)
binary_file_name: _ifcopenshell_wrapper.cpython-313-darwin.so
binary_python_version: 3.13
BTW,
uninstalling all Bonsais, restarting Blender todays 5.2 Beta, installing Bonsai daily - doesn't help.
I get the same warning ....
might be related: https://github.com/IfcOpenShell/IfcOpenShell/issues/8167
Thank you !
I added my info to the Issue thread.
