arising problems when updating/installing Bonsai on Mac
edited June 12 in General
Since a few weeks it began that updated Bonsai daily builds did not load in Blender 5.1.
While not having problems with 5.2 or 5.3.
Then I got the same 5.1 problem in 5.3 too, while 5.2 still ok. So for 5.3 I switched to BonsaiPR which worked.
Sometimes it loaded anyway after restarting Blender, sometimes not.
Anyway, meanwhile I reached a state where neither Bonsai daily nor PR will load on any Blender version :(
Could it be a problem that I have installed always both Bonsai versions, daily + PR ?
I do switch between these very seldom, but if, likely without restarting Blender, by deactivating the active, a bit of waiting and then activating the other version.
Do others experience similar problems installing Bonsai on Mac in general. Or switching between daily and PR in general ?
Usually I get a red error message (similar to restart hint after updating). Something like 2could not start/load Bonsai/more in Blender console)
In this case there are no usual entries in Blenders Scripting Tab.
And I do not find how to open Blender's console ....
  • OK, I got the message via Clipboard :
    os: Darwin
    os_version: Darwin Kernel Version 25.5.0: Mon Apr 27 20:41:15 PDT 2026; root:xnu-12377.121.6~2/RELEASE_ARM64_T6041
    python_version: 3.13.13
    architecture: ('64bit', 'Mach-O')
    machine: arm64
    processor: arm
    blender_version: 5.3.0 Alpha
    bonsai_version: 0.8.6-alpha260611
    bonsai_commit_hash: 0c993d3
    bonsai_commit_date: 2026-06-11T09:28:27+02:00
    bonsai_git_branch: v0.8.0
    last_actions:
    last_error: Traceback (most recent call last):
    File "/Users/user/Library/Application Support/Blender/5.3/extensions/raw_githubusercontent_com/bonsai/init.py", line 278, in
    import ifcopenshell.api
    File "/Users/user/Library/Application Support/Blender/5.3/extensions/.local/lib/python3.13/site-packages/ifcopenshell/init.py", line 98, in
    from .ifcopenshell_wrapper import get_log, logger
    ImportError: cannot import name 'logger' from 'ifcopenshell.ifcopenshell_wrapper' (/Users/user/Library/Application Support/Blender/5.3/extensions/.local/lib/python3.13/site-packages/ifcopenshell/ifcopenshell_wrapper.py)
    binary_file_name: _ifcopenshell_wrapper.cpython-313-darwin.so
    binary_python_version: 3.13
  • BTW,
    uninstalling all Bonsais, restarting Blender todays 5.2 Beta, installing Bonsai daily - doesn't help.
    I get the same warning ....
  • Thank you !
    I added my info to the Issue thread.
