[BlenderBIM] Having a dev version alongside stable version, external editor etc… (dev tricks)
Hi,
Dev version alongside stable version
I followed Blender Addon tutorial and now understand better how addon structure works but I also saw that it is not possible to have two version of blender bim addon installed (eg. one in /usr/share/blender/2.90/scripts/addons/blenderbim
and one in ~/.config/blender/2.90/scripts/addons/blenderbim
) because they have the same folder name. However changing folder name to blenderbim_dev
seems to be enough. Is it the best way to have a dev and stable version of an addon alongside ?
Changing code without restarting Blender (external editor)
I noticed that if I make some change on code base I need to restart Blender to see effects. Unload/reload seems to be not sufficient. Is there a way to work on addon code base without having to restart Blender to have you modification taken in account ?
Addon remote debugging (external editor)
I think I saw some videos for external debugging I will search for it except some one can explain how to debug remotely a blender addon. This is pretty much related the previous version as you often need to add some code somewhere for remote debugging.
Control Blender remotely
Is it possible to control Blender remotely. If so, how ?
Dev alongside stable
as long as they are not enabled at same time (leading in class names registration clash) you may simply use 2 folders at same location but with different names.
/blenderbim_dev
/blenderbim
Restart
It is the safest way to ensure python cache of sub modules are properly updated.
Remote debugging
There is an addon from JacquesLuke for Visual Studio Code, basically loading blender on the fly with your addon, solving both debug and restart issues.
Agree with @stephen_l but a couple of my own opinions. For dev alongside stable, Just git init, and then use git stash and/or branching?
For controlling Blender remotely, there are options for running Blender by command line, and you can feed it a Python script.
Thanks to you two.
I also found a great and fresh introduction to python coding in Blender :
And a good introduction to Blender code structure in C. Code is beautiful and well structured. First time something make me want to learn C (not sure it will happen for real although :-) ) :
https://video.blender.org/videos/watch/1501943c-1f16-4c4c-ad72-19c2e299796d
Maybe I should add these reference somewhere in wiki.
They look like fantastic resources and should definitely be added to the wiki! Thanks so much for sharing them!
Done. I also noticed a special chapter related to my questions in Blender Python API doc.
