If you are talking about the green selected spaces, this is classified as 'wall' in the CityJSON file, therefore is a wall in the IFC file. The 3D BAG is an automatically generated dataset based on LiDAR and 2D BAG data (thus vertical spaces are always walls, regardless where they are), so if you have any problems with wrong classifications you should ask those guys :)
I mean. "ifcroofs" are not shown. With the same data i can make ifc with FZKviewer that does show them after import. I'm not so into ifc what to ask them :) but i think this has something to do with how Blender writes down ifcroof... regards Hans
In Blender 3.1.0 with BlenderBIM version 0.0.220327 I get the following error after clicking Convert CityJSON to IFC:
Error: Python: Traceback (most recent call last):
File "C:\Users\cclaus\AppData\Roaming\Blender Foundation\Blender\3.1\scripts\addons\blenderbim\bim\module\gis\operator.py", line 44, in execute
converter.convert(city_model)
File "C:\Users\cclaus\AppData\Roaming\Blender Foundation\Blender\3.1\scripts\addons\blenderbim\libs\site\packages\ifccityjson\cityjson2ifc\cityjson2ifc.py", line 87, in convert
self.create_new_file()
File "C:\Users\cclaus\AppData\Roaming\Blender Foundation\Blender\3.1\scripts\addons\blenderbim\libs\site\packages\ifccityjson\cityjson2ifc\cityjson2ifc.py", line 132, in create_new_file
self.city_model.update_metadata()
AttributeError: 'CityJSON' object has no attribute 'update_metadata'. Did you mean: 'get_metadata'?
Should I make an IfcProject first? Do I have all the settings correct? Am I missing a step?
Is IfcCityJson still being maintained? I get the following message when I try to convert CityJson to IFC:
I'm on the latest stable release of BlenderBIM with Blender 3.4.1
File "C:\Users\cclaus\AppData\Roaming\Blender Foundation\Blender\3.4\scripts\addons\blenderbim\libs\site\packages\ifccityjson\cityjson2ifc\cityjson2ifc.py", line 128, in create_new_file
self.IFC_representation_context = ifcopenshell.api.run("context.add_context", self.IFC_model,
File "C:\Users\cclaus\AppData\Roaming\Blender Foundation\Blender\3.4\scripts\addons\blenderbim\libs\site\packages\ifcopenshell\api\__init__.py", line 66, in run
result = usecase_class(ifc_file, **settings).execute()
TypeError: Usecase.__init__() got an unexpected keyword argument 'context'
File "C:\Users\cclaus\AppData\Roaming\Blender Foundation\Blender\3.4\scripts\addons\blenderbim\bim\module\gis\operator.py", line 44, in execute
File "C:\Users\cclaus\AppData\Roaming\Blender Foundation\Blender\3.4\scripts\addons\blenderbim\libs\site\packages\ifccityjson\cityjson2ifc\cityjson2ifc.py", line 87, in convert
Hi Coen, I am not maintaining this anymore no, sorry.
I changed jobs & my focus is not on BIM anymore unfortunately. The error you get seems like an IfcOpenShell error? Probably because the version that IfcOpenShell that was used before had some other way of handling the context parameters. If you would like to we can do some debug session sometime & see if we could fix it? I think I can refresh my memory about CityJSON and if you know how to handle newer versions of IfcOpenShell, I'm sure we're going to get somewhere!
That's unfortunate :-(
Would be amazing, let's get in touch on some other private means of communication :-). I need to dive into IFC json a bit before I can ask you specific questions.
I tried diving into it, but I have no idea what I'm doing, I gives this message:
So I went to take a look at file blenderbim\libs\site\packages\ifccityjson\cityjson2ifc\cityjson2ifc.py on line 128:
@LaurensJN @pstrokap
I this file on line 128 C:\Users\cclaus\AppData\Roaming\BlenderFoundation\Blender\3.5\scripts\addons\blenderbim\libs\site\packages\ifccityjson\cityjson2ifc\cityjson2ifc.py
I replaced #self.IFC_representation_context = ifcopenshell.api.run("context.add_context", self.IFC_model **{"context": "Model"})
with self.IFC_representation_context = ifcopenshell.api.run("context.add_context", self.IFC_model, context_type="Model")
Saved the script, started Blender again. Tried to convert cityJson to IFC again:
Now I have another error which says:
File "C:\Users\cclaus\AppData\Roaming\Blender Foundation\Blender\3.5\scripts\addons\blenderbim\bim\module\gis\operator.py", line 44, in execute
File "C:\Users\cclaus\AppData\Roaming\Blender Foundation\Blender\3.5\scripts\addons\blenderbim\libs\site\packages\ifccityjson\cityjson2ifc\cityjson2ifc.py", line 88, in convert
self.create_metadata()
File "C:\Users\cclaus\AppData\Roaming\Blender Foundation\Blender\3.5\scripts\addons\blenderbim\libs\site\packages\ifccityjson\cityjson2ifc\cityjson2ifc.py", line 115, in create_metadata
epsg = self.city_model.get_epsg()
File "C:\Users\cclaus\AppData\Roaming\Blender Foundation\Blender\3.5\scripts\addons\blenderbim\libs\site\packages\cjio\cityjson.py", line 442, in get_epsg
raise ValueError(f"Invalid CRS string '{s}'. CRS needs to be formatted according to the OGC Name Type Specification: 'http://www.opengis.net/def/crs/{{authority}}/{{version}}/{{code}}'")
ValueError: Invalid CRS string 'urn:ogc:def:crs:EPSG::7415'. CRS needs to be formatted according to the OGC Name Type Specification: 'http://www.opengis.net/def/crs/{authority}/{version}/{code}'
I don't know how to fix this error: raise ValueError(f"Invalid CRS string '{s}'. CRS needs to be formatted according to the OGC Name Type Specification: 'http://www.opengis.net/def/crs/{{authority}}/{{version}}/{{code}}'")
It might be because of this line here in CJIO, that was added last year: cjio/cityjson.py#L441. I think the CityJSON file might be invalid according to this version of CJIO (the CityJSON parser).
So, your Coordinate Reference System (CRS) is defined as urn:ogc:def:crs:EPSG::7415. But it should be defined using the opengis URL. I think this is the correct one: https://www.opengis.net/def/crs/EPSG/0/7415. If you replace this in your CityJSON file, what happens?
I don't really understand how to upgrade a json file, I have installed cjio on my local python installation, but absolute lost on how to use the module.
If you have cjio installed (with pip install cjio), you can just run: cjio 3dbag_v210908_fd2cee53_2932.json upgrade save 3dbag_new.json on the command line, the new file will be 3dbag_new.json. As you might have seen in the issue, they deprecated the urn:... format of defining a CRS, but I don't know the reason for that. Upgrading the file would change the CRS to the correct definition
You're on the right track, but making a slight mistake: instead of running cjio on the command line, you start python on the command line and run cjio with python. Instead, just run cjio --help on the command line. This will only work if you have cjio installed in your global python packages.
When working with python, it is always good to have a virtual environment. This is a separate python environment, where you have your local python packages stored (the reason is that many packages depend on specific versions of other packages and if you have two of them installed that demand a different version, one of them will not work). Generally for each new project, you can make a new venv. What I suggest to you is:
(1) create a python3 venv using venv (this is in the standard python packages) on the command line, in the same directory as the CityJSON file: python3 -m venv venv
(2) now a virtual environment called venv is created. You first need to activate it: venv\bin\activate (windows) or . venv/bin/activate (linux)
(3) Now your virtual env is created and activated, you can install cjio: pip install cjio
(4) Run cjio on the command line: cjio --help or cjio 3dbag_v210908_fd2cee53_2932.json upgrade save 3dbag_new.json
Manage to upgrade the json file, now I have this error:
File "C:\Users\coen_\AppData\Roaming\Blender Foundation\Blender\3.5\scripts\addons\blenderbim\bim\module\gis\operator.py", line 44, in execute
File "C:\Users\coen_\AppData\Roaming\Blender Foundation\Blender\3.5\scripts\addons\blenderbim\libs\site\packages\ifccityjson\cityjson2ifc\cityjson2ifc.py", line 87, in convert
File "C:\Users\coen_\AppData\Roaming\Blender Foundation\Blender\3.5\scripts\addons\blenderbim\libs\site\packages\ifccityjson\cityjson2ifc\cityjson2ifc.py", line 128, in create_new_file
File "C:\Users\coen_\AppData\Roaming\Blender Foundation\Blender\3.5\scripts\addons\blenderbim\libs\site\packages\ifcopenshell\api\__init__.py", line 66, in run
This is good! That means the cityjson file was able to parse. Have you looked at this comment from before? As I said, I have not been able to maintain the repo and any changes in the ifcopenshell module can break the functioning of this module unfortunately. Have you looked at this comment from before:
@LaurensJN
Thanks for you answer I fixed that error too, now I get this one:
File "C:\Users\cclaus\AppData\Roaming\Blender Foundation\Blender\3.5\scripts\addons\blenderbim\libs\site\packages\ifccityjson\cityjson2ifc\cityjson2ifc.py", line 119, in create_metadata
self.properties["local_translation"]["TargetCRS"] = self.IFC_model.create_entity("IfcProjectedCrs", Name=f"epsg:{epsg}")
TypeError: 'NoneType' object does not support item assignment
Is CityJson actively being developed?
Getting this error
File "C:\Users\cclaus\AppData\Roaming\Blender Foundation\Blender\4.0\scripts\addons\blenderbim\bim\module\gis\operator.py", line 30, in execute
from ifccityjson.cityjson2ifc.cityjson2ifc import Cityjson2ifc
ModuleNotFoundError: No module named 'ifccityjson.cityjson2ifc'
File "<frozen importlib._bootstrap>", line 1027, in _find_and_load
File "<frozen importlib._bootstrap>", line 992, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
Or should I use the tool differently? If not, I think I should make a Github issue?
In Revit the ifcRoof become 'walls' after Blender conversion to IFC
In BricsCAD BIM no data result after importing.
Slightly related,
Managed with the Blender-osm add-on and BlenderBIM add-on to export the city centre of Moscow to IFC.
Which parameters should I provide?
I have the feeling this is not maintained anymore? Is there anything I can do to contribute?, this tool is so extremely useful.
on line 128:Took a look in the documentation:
https://blenderbim.org/docs-python/autoapi/ifcopenshell/api/context/add_context/index.html
Asked chatGPT:
Literally no idea what I should do to make IfcCityJson work
The
should now be**{"context_type": "Model"}
. I think, if I look at https://blenderbim.org/docs-python/autoapi/ifcopenshell/api/context/add_context/index.htmlBut the **{} Are a bit redundant, you could also use:
@LaurensJN
@pstrokap
I replaced
with
. But it should be defined using the opengis URL. I think this is the correct one:https://www.opengis.net/def/crs/EPSG/0/7415
. If you replace this in your CityJSON file, what happens?After upgrading the
cjio
module stille the same error :-(I don't think upgrading helps. I think you have to change the line where the CRS is defined.
Could I ask you where you got the CityJSON from? We should post an issue, that it should be possible to use the URN:OGC format too
I posted in issue in the CJIO repo: https://github.com/cityjson/cjio/issues/166
Also, if your file is 3D BAG, make sure to update them to V1.1 (see https://github.com/cityjson/cjio/issues/155)
The file you mean?
Downloaded them from here:
https://3dbag.nl/en/download?tid=2932
pip install cjio
), you can just run:cjio 3dbag_v210908_fd2cee53_2932.json upgrade save 3dbag_new.json
on the command line, the new file will be3dbag_new.json
. As you might have seen in the issue, they deprecated theurn:...
format of defining a CRS, but I don't know the reason for that. Upgrading the file would change the CRS to the correct definition@LaurensJN
How to use cjio in the terminal? Maybe I'm making some beginner rookie mistake?
I followed this:
https://cityjson.github.io/cjio/includeme.html#documentation
cjio --help
on the command line. This will only work if you have cjio installed in your global python packages.When working with python, it is always good to have a virtual environment. This is a separate python environment, where you have your local python packages stored (the reason is that many packages depend on specific versions of other packages and if you have two of them installed that demand a different version, one of them will not work). Generally for each new project, you can make a new venv. What I suggest to you is:
venv
(this is in the standard python packages) on the command line, in the same directory as the CityJSON file:python3 -m venv venv
venv
is created. You first need to activate it:venv\bin\activate
(windows) or. venv/bin/activate
(linux)(3) Now your virtual env is created and activated, you can install cjio:
pip install cjio
cjio --help
orcjio 3dbag_v210908_fd2cee53_2932.json upgrade save 3dbag_new.json
I hope this helps
@LaurensJN
Getting this error
