Report Class Type using the BlenderBIM IFCCSV tool
I've been able to create schedules of my IFC file using the IfcCSV tool in BlenderBIM, but one thing I can't figure out is the Attribute I need to report the name of the classification for each element (IfcWall, IfcFloor, etc.). What attribute name do I need to fetch the proper class for each element? The IFC file was exported from Revit.
I assumed it would be IfcBuildingElementType, but no such luck
Hi,
maybe this video from BIMvoice can help (BlenderBIM tour#1 with Dion Moult - IFCCSV)
IfcProduct?
Coming out as a blank field when I use .IfcElementType in the IFC Selector box of IFC CSV Import/Export
Is BlenderBIM spreadsheet an option for you to get what you want?
The attribute name you're after is "type" (all lowercase).
