[IfcOpenShell] Condensation of B-Rep geometry
Hi Moult
I extracted B-Rep geometry using geom module in ifcopenshell library.
There are around 150 vertices retrieved for one manhole. I want to check if there is a way to condense it in a meaningful way. I am extracting product and geometry data into a knowledge graph. I am not sure if storing 150 vertices for one manhole is a viable option.
Appreciate your thoughts.
Thanks
Shilpa
I don't understand what you mean with condensation
@Shilpa can you share the IFC file here, i might be able to show you how to reduce it via BlenderBIM.
@theoryshaw id be interested in seeing how you do that as well, any chance you'd be up for a screenshare maybe? @Coen I think @Shilpa meant to simplify the geometry, ie reduce the polygons/vertices.
