[BlenderBim] Error when importing schedule to a sheet
Hi Everyone,
So I'm getting an error when importing a schedule to an IFC file,
Dion managed to do it here in this example video:
@42:43 roughly
Has anyone had any success with placing schedules on sheets?
I've just added an example IFC file and ODS file that have the issue
Ok I think I just seriously misunderstood how to do this at this point
It does work but only if you do it in the correct order
Guide to adding schedules to sheets:
build schedule
SVG:
Add schedule to sheet
SVG Sheet with drawing and schedule:
Attached are the IFC files cleaned up slightly
The follow up question is how do you get the schedule to follow the formatting set in the ods document, the moment you have merged cells it freaks out
Ods/linbre Office calc
Built schedule from Blenderbim:
