Q: Javascript
Hi all, anyone is familiar with JS?
I have these Types
* Standard types
export const Types = {
Number: createType({
default: 0,
copy: copyValue,
clone: cloneValue
Boolean: createType({
default: false,
copy: copyValue,
clone: cloneValue
String: createType({
default: "",
copy: copyValue,
clone: cloneValue
Array: createType({
default: [],
copy: copyArray,
clone: cloneArray
Ref: createType({
default: undefined,
copy: copyValue,
clone: cloneValue
JSON: createType({
default: null,
copy: copyJSON,
clone: cloneJSON
So, how can I build Types that have units and type formation?
Like:
LengthMeasure type: Types.Real "mm"
// How to include units in types? for instance, LengthMeasure can be meter (m), centimeter (cm), and millimeter (mm)
or
Candela/Lumen (cd/lm) or (cd/klm)
or
maxLength
or
YYYY-MM-DDThh:mm:ss
You need a new type with two attributes: one containing the numerical value, and another containing the unit string (ideally not a string, it should belong to a set of enumerated constants, but the principle applies).
Thank you @Moult
I don't know having those two are expensive in GPU or CPU or not?
Because for instance Modelica just uses this simple line of code in C++ to do that:
