Q: Javascript
Hi all, anyone is familiar with JS?
I have these Types:
 * Standard types
export const Types = {
  Number: createType({
    default: 0,
    copy: copyValue,
    clone: cloneValue
  Boolean: createType({
    default: false,
    copy: copyValue,
    clone: cloneValue
  String: createType({
    default: "",
    copy: copyValue,
    clone: cloneValue
  Array: createType({
    default: [],
    copy: copyArray,
    clone: cloneArray
  Ref: createType({
    default: undefined,
    copy: copyValue,
    clone: cloneValue
  JSON: createType({
    default: null,
    copy: copyJSON,
    clone: cloneJSON
So, how can I build Types that have units and type formation?
Like:
LengthMeasure type: Types.Real "mm"
// How to include units in types? for instance, LengthMeasure can be meter (m), centimeter (cm), and millimeter (mm)
or
Candela/Lumen (cd/lm) or (cd/klm)
or
maxLength
or
YYYY-MM-DDThh:mm:ss
  • You need a new type with two attributes: one containing the numerical value, and another containing the unit string (ideally not a string, it should belong to a set of enumerated constants, but the principle applies).
  • edited July 2020
    Thank you @Moult
    I don't know having those two are expensive in GPU or CPU or not?
    class Accel {
      constructor(value, unit) {
        this.value = value || 0
        this.unit = unit || Units.MS
      clone() {
        return new Accel(this.value, this.unit)
      copy(accel) {
        this.value = accel.value
        this.unit = accel.unit
    Because for instance Modelica just uses this simple line of code in C++ to do that:
    parameter Real A= 6 "m^2"
