Crash course on learning to manipulate IFCs with IfcOpenShell and Python
  • @Moult said:
    The wiki has a crash course :)
    YESSSS! many thanks :)
  • edited July 2020
    The page now has some samples of the elusive "IFC selector / query syntax".
    Especially this solves the problem of "how do you efficiently query a subset of IFC elements from a file". The results of this query can be fed into many things, such as:
    • Importing or exporting only portions of a file the BlenderBIM Add-on
    • Doing a diff check on a portion of a file in IFCDiff
    • Doing clash detection on a portion of a file in IfcClash
    • Exporting a portion of a file to a CSV, or really any generation of any schedules, used in IFCCSV
    • Auditing a portion of a file in BIMTester
    @yorik - I hope it is interesting to you and maybe it can be used in FreeCAD too?
    JesusbillbitacovirtlangcarlopavBorna_Molnar
  • Very good for someone to get started and very good reference. Some hint: if a ifc is taken (uploaded with webget or even parsed directly from web) from a github account a new user even has a example to directly work with and exaclty see the same output as on the tutorial.
    Furthermore a good reference. Sometimes I do not do any Python and ifc for a few weeks and thus some commands are just gone.
    Moult
  • edited July 2020
    print(ifcopenshell.util.get_psets(wall))
    compiled latest 0.6 ifcopenshell but there is no ifcopenshell.util ? Do I need to compile 0.7 branch for this ?
  • edited July 2020
    Here
    You need to compile it from git source or to download it from IfcOpenBot.
  • edited July 2020
    $ python3
    Python 3.7.3 (default, Dec 20 2019, 18:57:59)
    [GCC 8.3.0] on linux
    Type "help", "copyright", "credits" or "license" for more information.
    >>> import ifcopenshell
    >>> ifcopenshell.version
    '0.6.0b0'
    >>> from ifcopenshell.util import get_psets
      File "<stdin>", line 1, in <module>
    ImportError: cannot import name 'get_psets' from 'ifcopenshell.util' (/usr/lib/python3/dist-packages/ifcopenshell/util/__init__.py)
    $ git log -1
    commit a337c480a99a9c5f199a360b684f08aa36548af8 (HEAD, origin/v0.6.0)
    Author: Dion Moult <dion@thinkmoult.com>
    Date:   Wed Jul 29 21:46:16 2020 +1000
        Support exporting IfcSweptDiskSolid for curves with no bevel profile
  • edited July 2020
    Just a mistake on wiki. get_psets is in element module not util directly :
    import ifcopenshell.util
    ifcopenshell.util.element.get_psets(wall)
    Moult
  • $ python3
    >>> import ifcopenshell
    '0.6.0b0'
    >>> from ifcopenshell.util.element import get_psets
  • Very useful information!
    I still remember that I knew @Moult because I was learning ifcopenshell-Python, and I contacted him by email to ask if he has more examples. He said that I could come to OSArch to communicate, so I came here.
    Moult
  • get_psets does not support IfcComplexProperty. This is used to save properties of each material layer of a wall.
    https://standards.buildingsmart.org/IFC/RELEASE/IFC2x3/TC1/HTML/ifcpropertyresource/lexical/ifccomplexproperty.htm
  • file from here ... https://forum.freecadweb.org/viewtopic.php?t=14059&start=20#p123072
    >>> import ifcopenshell
    >>> ifc = ifcopenshell.open("C:/Users/BHA/Downloads/simple-building.ifc")
    >>> get_psets(ifc[354])
    failed to load properties: entity instance of type 'IfcQuantityLength' has no attribute 'IsDefinedBy'
      File "C:\0_BHA_privat\progr\FreeCAD_0.19.xxxxx_Py3Qt5\bin\lib\site-packages\ifcopenshell\util\element.py", line 9, in get_psets
        for relationship in element.IsDefinedBy:
      File "C:\0_BHA_privat\progr\FreeCAD_0.19.xxxxx_Py3Qt5\bin\lib\site-packages\ifcopenshell\entity_instance.py", line 65, in __getattr__
        "entity instance of type '%s' has no attribute '%s'" % (self.wrapped_data.is_a(), name))
    AttributeError: entity instance of type 'IfcQuantityLength' has no attribute 'IsDefinedBy'
  • edited August 2020
    >>> for ps, p in get_psets(ifc[345]).items():
    ...     print("{} --> {}".format(ps, p))
    WallQuantities --> {'GrossVolume': 6.0, 'NetVolume': 6.0, 'GrossSideArea': 24.0, 'NetSideArea': 24.0, 'NominalLength': 8.0, 'NominalWidth': 0.25, 'GrossFootprintArea': 2.0, 'NominalHeight': 3.0}
    Allplan Attributes --> {'Allright_Bauteil_ID': IfcDescriptiveMeasure('1007HWa0000000011'), 'Einheit': IfcDescriptiveMeasure('St'), 'Objektname': IfcDescriptiveMeasure('Mehrsch-Wand'), 'NOI_UUID': IfcDescriptiveMeasure('5a6837a3-f217-44ed-997f-04834a2db582--11'), 'IFC-Objekttyp': IfcLabel('IfcWallStandardCase')}
    but if there are really some layers it misses some properties ...
    >>> for ps, p in get_psets(ifc[437]).items():
    Pset_WallCommon --> {'LoadBearing': IfcBoolean(.T.)}
    AllplanAttributes --> {'Allright_Bauteil_ID': IfcDescriptiveMeasure('0033HWa0000000022'), 'Umbaukategorie': IfcLabel('Neubau'), 'Einheit': IfcDescriptiveMeasure('St'), 'Objektname': IfcDescriptiveMeasure('Mehrsch-Wand'), 'Bezeichnung': IfcDescriptiveMeasure('Mehrschichten-Wand'), 'Material': IfcDescriptiveMeasure('Mehrschichten-Wand'), 'NOI_UUID': IfcDescriptiveMeasure('2c3f7016-d5f2-4b9b-9ea7-6de7b5e546cf--22'), 'IFC-Objekttyp': IfcDescriptiveMeasure('IfcWall')}
  • up ... @Moult have you noticed the problem ?
  • @bernd it works for me, are you sure you have the latest file?
    See my results:
    >>> for ps, p in ifcopenshell.util.element.get_psets(f[437]).items():
    AllplanAttributes --> {'Allright_Bauteil_ID': IfcDescriptiveMeasure('0033HWa0000000022'), 'Umbaukategorie': IfcLabel('Neubau'), 'Einheit': IfcDescriptiveMeasure('St'), 'Objektname': IfcDescriptiveMeasure('Mehrsch-Wand'), 'Bezeichnung': IfcDescriptiveMeasure('Mehrschichten-Wand'), 'Material': IfcDescriptiveMeasure('Mehrschichten-Wand'), 'NOI_UUID': IfcDescriptiveMeasure('2c3f7016-d5f2-4b9b-9ea7-6de7b5e546cf--22'), 'IFC-Objekttyp': IfcDescriptiveMeasure('IfcWall'), 'Object Layer Attributes #1': {'id': 467, 'type': 'IfcComplexProperty', 'Name': 'Object Layer Attributes #1', 'Description': 'Layer #1', 'UsageName': 'Layer #1', 'properties': {'Allright_Bauteil_ID': IfcDescriptiveMeasure('0033Wa 0000000026'), 'Umbaukategorie': IfcLabel('Neubau'), 'Einheit': IfcDescriptiveMeasure('St'), 'Gewerk': IfcDescriptiveMeasure('Betonarbeiten'), 'Objektname': IfcDescriptiveMeasure('Mehrschichten-Wand'), 'Bezeichnung': IfcDescriptiveMeasure('Mehrschichten-Wand'), 'Material': IfcDescriptiveMeasure('Fertigelement Beton'), 'statisch_tragend': IfcBoolean(.T.), 'Außenbauteil': IfcBoolean(.F.), 'NOI_UUID': IfcDescriptiveMeasure('2c3f7016-d5f2-4b9b-9ea7-6de7b5e546cf--26'), 'IFC-Objekttyp': IfcDescriptiveMeasure('IfcWall')}}, 'Object Layer Attributes #2': {'id': 491, 'type': 'IfcComplexProperty', 'Name': 'Object Layer Attributes #2', 'Description': 'Layer #2', 'UsageName': 'Layer #2', 'properties': {'Allright_Bauteil_ID': IfcDescriptiveMeasure('0033Wa 0000000025'), 'Umbaukategorie': IfcLabel('Neubau'), 'Einheit': IfcDescriptiveMeasure('m³'), 'Gewerk': IfcDescriptiveMeasure('Betonarbeiten'), 'Objektname': IfcDescriptiveMeasure('Mehrschichten-Wand'), 'Bezeichnung': IfcDescriptiveMeasure('Mehrschichten-Wand'), 'Material': IfcDescriptiveMeasure('Ortbeton'), 'statisch_tragend': IfcBoolean(.T.), 'Außenbauteil': IfcBoolean(.F.), 'NOI_UUID': IfcDescriptiveMeasure('2c3f7016-d5f2-4b9b-9ea7-6de7b5e546cf--25'), 'IFC-Objekttyp': IfcDescriptiveMeasure('IfcWall')}}, 'Object Layer Attributes #3': {'id': 515, 'type': 'IfcComplexProperty', 'Name': 'Object Layer Attributes #3', 'Description': 'Layer #3', 'UsageName': 'Layer #3', 'properties': {'Allright_Bauteil_ID': IfcDescriptiveMeasure('0033Wa 0000000024'), 'Umbaukategorie': IfcLabel('Neubau'), 'Einheit': IfcDescriptiveMeasure('St'), 'Gewerk': IfcDescriptiveMeasure('Betonarbeiten'), 'Objektname': IfcDescriptiveMeasure('Mehrschichten-Wand'), 'Bezeichnung': IfcDescriptiveMeasure('Mehrschichten-Wand'), 'Material': IfcDescriptiveMeasure('Daemmung'), 'statisch_tragend': IfcBoolean(.T.), 'Außenbauteil': IfcBoolean(.F.), 'NOI_UUID': IfcDescriptiveMeasure('2c3f7016-d5f2-4b9b-9ea7-6de7b5e546cf--24'), 'IFC-Objekttyp': IfcDescriptiveMeasure('IfcWall')}}, 'Object Layer Attributes #4': {'id': 538, 'type': 'IfcComplexProperty', 'Name': 'Object Layer Attributes #4', 'Description': 'Layer #4', 'UsageName': 'Layer #4', 'properties': {'Allright_Bauteil_ID': IfcDescriptiveMeasure('0033Wa 0000000023'), 'Umbaukategorie': IfcLabel('Neubau'), 'Einheit': IfcDescriptiveMeasure('m²'), 'Objektname': IfcDescriptiveMeasure('Mehrschichten-Wand'), 'Bezeichnung': IfcDescriptiveMeasure('Mehrschichten-Wand'), 'Material': IfcDescriptiveMeasure('Fertigelement Beton'), 'statisch_tragend': IfcBoolean(.T.), 'Außenbauteil': IfcBoolean(.F.), 'NOI_UUID': IfcDescriptiveMeasure('2c3f7016-d5f2-4b9b-9ea7-6de7b5e546cf--23'), 'IFC-Objekttyp': IfcDescriptiveMeasure('IfcWall')}}}
    Dion I musst somehow have been overwritten the file on FreeCAD (if I am at my computer at work I only use downloadable FreeCAD version which includes ifcopenshell) update ... works great here too.
    >>> f=ifc
    Is there a special reason why you did not make it work this way?
    f[437].get_psets()
  • @bernd I guess we just started collecting functions and haven't yet started to organise them better.
    But for this one, I agree it totally makes sense :) Perhaps post a comment in the Github issue and ask @aothms what his thoughts are?
    https://github.com/IfcOpenShell/IfcOpenShell/issues/829#issuecomment-670489327
