The page now has some samples of the elusive "IFC selector / query syntax".
Especially this solves the problem of "how do you efficiently query a subset of IFC elements from a file". The results of this query can be fed into many things, such as:
Importing or exporting only portions of a file the BlenderBIM Add-on
Doing a diff check on a portion of a file in IFCDiff
Doing clash detection on a portion of a file in IfcClash
Exporting a portion of a file to a CSV, or really any generation of any schedules, used in IFCCSV
Auditing a portion of a file in BIMTester
@yorik - I hope it is interesting to you and maybe it can be used in FreeCAD too?
Very good for someone to get started and very good reference. Some hint: if a ifc is taken (uploaded with webget or even parsed directly from web) from a github account a new user even has a example to directly work with and exaclty see the same output as on the tutorial.
Furthermore a good reference. Sometimes I do not do any Python and ifc for a few weeks and thus some commands are just gone.
$ python3
Python 3.7.3 (default, Dec 20 2019, 18:57:59)
[GCC 8.3.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import ifcopenshell
>>> ifcopenshell.version
'0.6.0b0'
>>> from ifcopenshell.util import get_psets
File "<stdin>", line 1, in <module>
ImportError: cannot import name 'get_psets' from 'ifcopenshell.util' (/usr/lib/python3/dist-packages/ifcopenshell/util/__init__.py)
$ git log -1
commit a337c480a99a9c5f199a360b684f08aa36548af8 (HEAD, origin/v0.6.0)
Author: Dion Moult <dion@thinkmoult.com>
Date: Wed Jul 29 21:46:16 2020 +1000
Support exporting IfcSweptDiskSolid for curves with no bevel profile
$ python3
>>> import ifcopenshell
'0.6.0b0'
>>> from ifcopenshell.util.element import get_psets
Very useful information!
I still remember that I knew @Moult because I was learning ifcopenshell-Python, and I contacted him by email to ask if he has more examples. He said that I could come to OSArch to communicate, so I came here.
>>> import ifcopenshell
>>> ifc = ifcopenshell.open("C:/Users/BHA/Downloads/simple-building.ifc")
>>> get_psets(ifc[354])
failed to load properties: entity instance of type 'IfcQuantityLength' has no attribute 'IsDefinedBy'
File "C:\0_BHA_privat\progr\FreeCAD_0.19.xxxxx_Py3Qt5\bin\lib\site-packages\ifcopenshell\util\element.py", line 9, in get_psets
for relationship in element.IsDefinedBy:
File "C:\0_BHA_privat\progr\FreeCAD_0.19.xxxxx_Py3Qt5\bin\lib\site-packages\ifcopenshell\entity_instance.py", line 65, in __getattr__
"entity instance of type '%s' has no attribute '%s'" % (self.wrapped_data.is_a(), name))
AttributeError: entity instance of type 'IfcQuantityLength' has no attribute 'IsDefinedBy'
Dion I musst somehow have been overwritten the file on FreeCAD (if I am at my computer at work I only use downloadable FreeCAD version which includes ifcopenshell) update ... works great here too.
YESSSS! many thanks :)
compiled latest 0.6 ifcopenshell but there is no ifcopenshell.util ? Do I need to compile 0.7 branch for this ?
Here
You need to compile it from git source or to download it from IfcOpenBot.
Just a mistake on wiki.
get_psets
is in element module notutil
directly ::-)
get_psets does not support IfcComplexProperty. This is used to save properties of each material layer of a wall.
https://standards.buildingsmart.org/IFC/RELEASE/IFC2x3/TC1/HTML/ifcpropertyresource/lexical/ifccomplexproperty.htm
file from here ... https://forum.freecadweb.org/viewtopic.php?t=14059&start=20#p123072
@bernd added support: https://github.com/IfcOpenShell/IfcOpenShell/commit/2a22acfdc936bc9ed6d2ff0ec36e76287da08d56
By the way, it's
ifc[345]
notifc[354]
but if there are really some layers it misses some properties ...
up ... @Moult have you noticed the problem ?
@bernd it works for me, are you sure you have the latest file?
See my results:
Is there a special reason why you did not make it work this way?
f[437].get_psets()
@bernd I guess we just started collecting functions and haven't yet started to organise them better.
But for this one, I agree it totally makes sense :) Perhaps post a comment in the Github issue and ask @aothms what his thoughts are?
https://github.com/IfcOpenShell/IfcOpenShell/issues/829#issuecomment-670489327
