If it's not empty it's used when you're creating sheets from the layout to create a pdf file from svg.
You can try it out with [['inkscape', svg, '-o', pdf]] (need to have inkscape in your path - it should be accessible with inkscape command from the system terminal).
When this command is executed svg is replaced with C:/path/to/A00 - UNTITLED.svg and pdf with C:/path/to/A00 - UNTITLED.pdf.
[['inkscape', svg, '-o', pdf]](need to haveinkscapein your path - it should be accessible withinkscapecommand from the system terminal).When this command is executed
svgis replaced withC:/path/to/A00 - UNTITLED.svgand pdf withC:/path/to/A00 - UNTITLED.pdf.Hey @Andrej730
I discussed this briefly with @Moult before for dxf & pdf export but never managed to get it working,
how he described it is:
Runs only after you have used 'Create sheets' button. (is this still needed?)
DXF:
In SVG to DXF Command:
[['inkscape', svg, '-o', eps], ['pstoedit', '-dt', '-f', 'dxf:-polyaslines -mm', eps, dxf, '-psarg', '-dNOSAFER']]
PDF:
SVG to PDF command:
NB:
Must install Inkscape & pstoedit (and set the PATH for inkscape : https://www.maketecheasier.com/what-is-the-windows-path/ )
Is this process still the same?
I've attempted it again and found 2 issues
1) It produces an error, I've posted as an issue on the github:
https://github.com/IfcOpenShell/IfcOpenShell/issues/3647
2) I can't seem to remove the command once I've pasted it in without reinstalling BlenderBim, is there a save preferences button I am not aware of?
The issue has been semi resolved:
if you replace
with
[['inkscape.exe', svg, '-o', pdf]]
it works for me!
Yes, it will run the commands specified in SVG to PDF / SVG to DXF on "Create Sheets".
Not sure, can't reproduce this. Do you have "Auto-Save Preferences" enabled? Maybe it could help
Ahh I'm being dumb, I do have the auto save preferences enabled, but once I manually save it, it works fine.
