Naming LightingFixtures
When I create an element type of a lighting fixture the name in the outliner will be IfcFlowTerminal/FlowTerminal is there a way to give another name after the backslash or is this against some ifc naming convention. This would need to be already in the element type or is there a bulk rename option.
you can rename it to anything, after the foward slash.
not sure about a bulk renaming utility. A search/replace in the IFC text file might work.
Press Ctrl + F2.
There's native Blender functionality to batch rename things:
And in the add-on settings of BlenderBIM you could select type instead of class,
Feature request, can't the default be set to By Type? I don't know why anyone would use the class since the IFC element is alreayd in front of the slash.
I guess there is a bulk renaming...
https://www.dropbox.com/scl/fi/0zue1pn8wpm663xuvziq4/2023-09-18_21-56-27_Blender_blender.mp4?rlkey=bwkpy4p1nqp0uxcgqy6wutvmh&dl=0
Thanks to a recent change by @Andrej730 you can just bulk rename and ignore the whole / slash thing, it'll auto insert slashes as necessary.
