Window In Cavity Wall
Hello everyone,
I need help with an issue involving a single window cut through multiple walls using the same void. You can see the issue in the video below.
To give some context: as a workaround for the lack of material layer visualization in Bonsai See hereI modelled each element of my cavity wall individually:
The problem I'm facing is figuring out how to cut out windows across all the layers of the cavity wall without having to create separate voids for each wall. Ideally, I'd like the window to automatically cut through all the wall elements without manually adding voids.
As seen in the video, every time I attempt to use the void from the window itself, I either encounter an error or it doesn't save when reopened.
My question is:
- Is this a bug?
- Is this a feature that hasn't been implemented?
- Am I approaching this the wrong way?
See the attached file if needed
https://drive.google.com/file/d/1r5Ksb0IcsBoOxV7HpJzRoOtUuIHAMKah/view?usp=drive_link
I like doing it this way....https://github.com/IfcOpenShell/IfcOpenShell/issues/5384#issuecomment-2359525586
