Also can we,
1. Change the precision of dimensions
2. Add an alternate unit with the primary unit. ( for e.g. <------------ 1m (3.28 ft) ------------> )
How to change the precision on drawing dimensions.
I think the method you used above, would only change during the blender session. That is, if you opened the .ifc anew, the units would reset back to the units in the .ifc file.
This functionality does not exist yet. Would be a good feature request.
Is there a way I can change the units in the IFC file. I tried the Geometry>Units in the Projects Overview, but its not working.
Tried this method; it works fine. Thank you !
How to display the area of space in square feets in the Space Tag, Is there a hack? Actually I dont want to change the project units to imperial, only the area.
Gah. Never mind. Numbers are totally wrong. Length, not area.
That field is only formatting. It does no conversion. So it would make 10.5 (representing 10.5 sqm) into 10' - 6" (representing a length that is completely wrong. There isn't an obvious way to do what you ask without changing your units. Maybe others have better suggestions.
Also can we,
Got a solution! Don't know whether it's the right way. Is there any other way @theoryshaw @brunopostle @bruno_perdigao @JanF
Yeah!
Try the
ConvertLengthUnitpatch...Thank you @theoryshaw , it worked . Is there any way I can format the dimension more simple in decimal points as shown below
Sorry, i don't think that's possible. Would be a good feature request, if you'd like to post one.
i took a stab at it, but it needs refining...
https://github.com/IfcOpenShell/IfcOpenShell/pull/5922/files
@arunarchitect Also, you might know about this already, but you can round out the imperial fractions too, to 'clean it up' a little.
Nice😃
@bruno_perdigao came to the rescue!
https://github.com/IfcOpenShell/IfcOpenShell/commit/db1d8d938f3d15a6d94e71ee386bf6199294e5fc
If you'd like to help fund Bonsai development: https://opencollective.com/opensourcebim
Would be nice is the syntax supported simple math.
We live in a whole different world now, people.
https://github.com/IfcOpenShell/IfcOpenShell/pull/7411
