For those times your dimension string text flips upside down, here's a little script to reverse the
For those times your dimension string text flips upside down, here's a little script to reverse the vertices of the dimension, so the text reads correctly again.
import bpy
import bmesh
obj = bpy.context.edit_object
bm = bmesh.from_edit_mesh(obj.data)
# Find the selected edge loop
edges = [e for e in bm.edges if e.select]
verts = []
if edges:
edge = edges[0]
v1, v2 = edge.verts
visited = {v1}
verts.append(v1)
current = v1
while True:
link_edges = [e for e in current.link_edges if e in edges]
next_vert = None
for e in link_edges:
other = e.other_vert(current)
if other not in visited:
next_vert = other
break
if not next_vert:
break
visited.add(next_vert)
verts.append(next_vert)
current = next_vert
# Reverse the order by duplicating vertices and reassigning edges
for i in range(len(verts)//2):
verts[i].co, verts[-1-i].co = verts[-1-i].co.copy(), verts[i].co.copy()
bmesh.update_edit_mesh(obj.data)
Made it a small plugin. AI was involved. :)
Nice, do we run this from blender script or how to install it?
put here, and enable plugin.
Ah thanks! Is that target scaling addon possibly scaling an object to a known measurement? If so, mind sharing where you got it ? ;)
np https://community.osarch.org/discussion/2660/import-dxf-of-a-drawing-scaling-it-and-adding-it-as-an-ifc-to-a-project/p1
haha what, I see that i commented there too but it got forgotten... Thanks again ;)
np... you should now be a master at installing plugins. ;)
lives here now: https://hub.openingdesign.com/OpeningDesign/Utility_Apps/src/commit/54d824cb7d89f9dc344c88d58e3e17bf44581296/Blender/addons/Reverse Polyline Vertices/init.py
Hopefully fixed 'er: https://github.com/IfcOpenShell/IfcOpenShell/commit/3b83f978abd09df620d173b508179866b696abff
