For those times your dimension string text flips upside down, here's a little script to reverse the
edited April 2025 in General
For those times your dimension string text flips upside down, here's a little script to reverse the vertices of the dimension, so the text reads correctly again.
import bpy
import bmesh
obj = bpy.context.edit_object
bm = bmesh.from_edit_mesh(obj.data)
# Find the selected edge loop
edges = [e for e in bm.edges if e.select]
verts = []
if edges:
    edge = edges[0]
    v1, v2 = edge.verts
    visited = {v1}
    verts.append(v1)
    current = v1
    while True:
        link_edges = [e for e in current.link_edges if e in edges]
        next_vert = None
        for e in link_edges:
            other = e.other_vert(current)
            if other not in visited:
                next_vert = other
                break
        if not next_vert:
            break
        visited.add(next_vert)
        verts.append(next_vert)
        current = next_vert
    # Reverse the order by duplicating vertices and reassigning edges
    for i in range(len(verts)//2):
        verts[i].co, verts[-1-i].co = verts[-1-i].co.copy(), verts[i].co.copy()
bmesh.update_edit_mesh(obj.data)
JanFMassimofalken10vdlcarlopavsteverugiGerardTOwura_qu
  • edited April 2025
    Made it a small plugin. AI was involved. :)
    bl_info = {
        "name": "Reverse Polyline Vertices",
        "author": "ChatGPT + Ryan",
        "version": (1, 0),
        "blender": (2, 80, 0),
        "location": "Mesh > Vertices > Reverse Polyline Vertices",
        "description": "Reverses the vertex order along a selected polyline in edit mode",
        "category": "Mesh",
    import bpy
    import bmesh
    class MESH_OT_reverse_polyline_vertices(bpy.types.Operator):
        """Reverse the vertex positions of a selected polyline"""
        bl_idname = "mesh.reverse_polyline_vertices"
        bl_label = "Reverse Polyline Vertices"
        bl_options = {'REGISTER', 'UNDO'}
        @classmethod
        def poll(cls, context):
            return (context.active_object is not None and
                    context.active_object.type == 'MESH' and
                    context.mode == 'EDIT_MESH')
        def execute(self, context):
            obj = context.edit_object
            if not edges:
                self.report({'WARNING'}, "No selected edges found")
                return {'CANCELLED'}
            verts = []
            edge = edges[0]
            v1, v2 = edge.verts
            visited = {v1}
            verts.append(v1)
            current = v1
            while True:
                next_vert = None
                        next_vert = other
                        break
                if not next_vert:
                    break
                current = next_vert
            if len(verts) < 2:
                self.report({'WARNING'}, "Not enough vertices to reverse")
            self.report({'INFO'}, "Polyline vertex order reversed")
            return {'FINISHED'}
    def menu_func(self, context):
        self.layout.operator(MESH_OT_reverse_polyline_vertices.bl_idname)
    def register():
        bpy.utils.register_class(MESH_OT_reverse_polyline_vertices)
        bpy.types.VIEW3D_MT_edit_mesh_vertices.append(menu_func)
    def unregister():
        bpy.types.VIEW3D_MT_edit_mesh_vertices.remove(menu_func)
        bpy.utils.unregister_class(MESH_OT_reverse_polyline_vertices)
    if __name__ == "__main__":
        register()
    Darth_BlenderMassimofalken10vdlwalpaAce
  • Nice, do we run this from blender script or how to install it?
  • put here, and enable plugin.
    jes_r
  • edited May 2025
    Ah thanks! Is that target scaling addon possibly scaling an object to a known measurement? If so, mind sharing where you got it ? ;)
  • haha what, I see that i commented there too but it got forgotten... Thanks again ;)
  • np... you should now be a master at installing plugins. ;)
