When you draw a wall object I see each section of the wall has a GlobalId.
I cant see in the object properties the length of the object?
I do like in Revit when drawing a wall there is some dimension feedback annotation, can we do that in Bonsai?
Dear Skynet, can you make a PR? ;)
I think it would be a good tool to be integrated as well, but will leave it to other more qualified to make the integration. Want to try?
Maybe it would make sense to have a read only field added to that part of the screen? so for the wall to add the depth (which comes from the material definition in this case) ?
I have seen that the editing tools get refreshed with the data of the selected item in latest builds (it was not the case in some older ones)
wouldn't it be a kind of duplicate of what already available ?
@steverugi you are right! It is true that the N panel has the bounding box information. The same info is in different places. @wayneh150 What do you think? if you press N, you will have that information already there.
Actually I was looking to the sourcecode and there is BIM_PT_derived_coordinates(Panel). So in Geometry & Materials -> Placement -> Derived coordinates: XYZ Dimensions
Yes that's good, so it would be good to have that information available when drawing and editing IFC walls.
Much like AutoCAD when you draw a line maybe?
Having some handy visual feedback somewhere I feel would be useful.
@wayneh150
Skynet wrote a script...
@theoryshaw why not a PR 😉?.
Really handy.
Best, Ryan
Having that information on the model would be useful, if the user would like to adjust things,
I like the look of this QTO stuff too no more calculating piles, caps and slabs :)
@theoryshaw Sure! :) Where would you think it would make sense to add it?
Add the "Toggle Edge Lenghts" as an icon in the "Explore Tool"?
Thanks!
So that dimension tool is good, could those values remain while the wall tool is selected, would that be easier?
(I see also with that tool if you want to measure something using the same point that s not possible)
@wayneh150
In my previous post I forgot to mention @theoryshaw 's method using the Explore Tool > Shift+M to turn on the Measure Tool
Not having figured out how to only show certain values it looks a bit too messy for me, but it's a matter of taste of course
@falken10vdl
