Nice Selection Addon
stumbles upon this Addon in Blender Extensions https://extensions.blender.org/add-ons/cross-select/reviews/ it provides L to R / R to L CAD type selections, something I have missed when using Blender :)
steverugizoomerJulianduarteframos
  • Oh man, that's awesome! Thanks for sharing!
  • I vote this should be default in BB! :)
    Nigelfalken10vdlsteverugiFranSeoanewalpazoomerRoelberndatomkarincaEnzoA7
  • edited January 7
    Oh my God ...
    how did I miss that in Blender. Thank you very much
    I always wanted my Modo back. I always had "toggle X-Ray" enabled and went to Shaded Mode to do get a reliable Selection. Selecting by "Face Center point" and made me nuts. I hope it can select also occluded Faces .....
    EDIT : OK, not in Edit Mode. At least it works in Object Mode ....
    actually, it does work in Edit mode, scroll down the T-panel and you'll see the Icon
    zoomer
    Interesting, didn't know I have to/can activate it.
    When activated, it works like a charm and I get colored Marquee fences - Great.
    falken10vdlNigel
  • edited January 9
    Very good! Missing in action!
    My cent, this demo
    steverugiwalpazoomerfalken10vdl
  • @magicalcloud_75 said:
    My cent, this demo
    Thank you very much !
    I wasn't aware of Blenders Filter (Sub) Options in Outliner .....
    So far I think choosing "Selected" does help to work with crowded Files
    (If it does not negatively interfere elsewhere ... So far I all time moved cursor over Outliner and pressed NumComma to find my selected Object in Outliner)
  • edited June 7
    Used AI to integrate the cross-select functionality natively to Bonsai...
    https://github.com/IfcOpenShell/IfcOpenShell/pull/8153
    MassimoNigelcarlopavzoomerwalpaEnzoA7
  • Great.
    I have already a similar AddOn for Blender :
    https://extensions.blender.org/add-ons/cross-select/?utm_source=blender-5.2.0-lts-beta
    To make Blender a bit more (CAD) industry conform.
    But did I get that correct that your tool eliminates the need to switch to/between Editing Modes ?
    (Selecting Objects/Faces/Edges/Vertices at a time ?)
    That would be super cool.
    I was used to such perfect Mesh Selection options in Modo in the past and now still suffer from Blender's missing select-through control or its Face-Center-Point.
  • This 'is' the Cross Select code integrated into Bonsai. It's basically turned on with all Bonsai tools, so you don't have to specifically initiate the Cross-Select tool... it's always on.
    zoomerNigel
